Fasteners and fixings are an integral part of DIY, this section has a large amount of videos showing how to fix to most substrates including plasterboard, tiles and concrete.
  • 03:19 Popular Dewalt Gasbeton aerated concrete fixing
    by Admin Added 1,012 Views / 0 Likes
    The Dewalt Gasbeton is an aerated concrete fixing that can be used to fix items to walls made from aerated concrete blocks such as aircrete, thermolite, durox, toplite or celcon blocks. The Dewalt gasbeton fixings do require a large diameter screw to work
    by Admin Added 1,238 Views / 0 Likes
  • 05:44 Popular Dewalt wall dogs | screw anchors
    by Admin Added 1,212 Views / 1 Likes
    Dewalt wall dogs are an all steel, tension free, one piece threaded fastener that is suitable for use in most substrates including concrete, stone, brick, plasterboard and timber. When using the dewalt wall dogs in concrete, brick or masonry it is a good
  • 02:32 Popular Dry wall screws | Plasterboard screws
    by Admin Added 1,231 Views / 0 Likes
    Dry wall screws or plasterboard screws are used for fixing plasterboard sheets to either wood or metal partitions or joists. It’s essential to use these screws as they are very strong and durable and the bugle head shape of the screw is designed to
  • 04:17 Popular Fixing to tiles using silicone
    by Admin Added 3,085 Views / 0 Likes
    In some instances you can fix items to tiled walls using silicone, this is a quick and easy way and means that the tile does not need drilling.
  • 04:22 Popular Foam fix plasterboard
    by Admin Added 2,115 Views / 1 Likes
    Plasterboard fixing foam is a quicker and cleaner solution than using dry wall adhesive. Sometimes it is easy to use and sometimes it is more difficult as in this example
  • 05:11 Popular GeeFix plasterboard fixings
    by Admin Added 1,558 Views / 0 Likes
    Get GeeFix fixings here- http://fave.co/1Vlfqgu GeeFix cavity fixings can be used in most sheet materials to provide a strong and durable fixing. These fixings can be used in cavities as narrow as 30mm, they can also be used in board thicknesses from 3mm
  • 04:33 Popular GripIt fixings
    GripIt fixings
    by Admin Added 692 Views / 0 Likes
    GripIt fixings are a quick and easy way of fixing to plasterboard or drywall. These fixings are easy to use and currently come in four different sizes depending on what you are fixing to the plasterboard or drywall. Currently 4 different GripIt fixing are
    GripIt fixings
    by Admin Added 1,363 Views / 0 Likes
  • 08:03 Popular Hanging a mirror on a solid wall
    by Admin Added 1,112 Views / 0 Likes
    Here we install a large mirron on a solid wall using wall plugs and screws
  • 04:54 Popular hollow wall anchors
    hollow wall anchors
    by Admin Added 2,497 Views / 0 Likes
    Hollow wall anchors are an easy way to fix to plasterboard
  • 03:49 Popular How to cut a bolt without damaging the threads
    by Admin Added 4,581 Views / 0 Likes
    This video shows how to cut a bolt using a hacksaw or a pair of electrical crimping pliers. Cutting a bolt has never been so easy!
  • 03:09 Popular How to find a stud in a stud wall
    by Admin Added 5,124 Views / 4 Likes
    A cheap way of finding a stud in a stud partition wall is to use a magnet. The magnet finds the heads on the screws or nails that were used to fix the plasterboards- hey presto you have found the studs!
  • 06:58 Popular How to fix a shelf to a dot and dab wall using corefix fixings
    by Admin Added 187 Views / 0 Likes
    In this video I fix a floating shelf to a dot and dab wall, if you are not familiar with a dot and dabbed wall (direct bond method), there is an article here, which explains about it- http://www.ultimatehandyman.co.uk/how-to/plastering/direct-bond Fixing
  • 06:18 Popular How to Fix a Shelf to a Plasterboard Wall
    by Admin Added 1,379 Views / 0 Likes
    Buy snaptoggles here- http://fave.co/1Ozdquh This video shows how to fix a shelf to a plasterboard wall. If possible it is best to always try and fix to one of the studs, but when that is not possible you can fix to plasterboard as long as you chose the c
  • 05:42 Popular How to fix heavy items to plasterboard / drywall
    by Admin Added 1,336 Views / 0 Likes
    One of the questions I get asked regularly is how to fix heavy items such as a TV to plasterboard or drywall. Unfortunately there are no plasterboard fixings available that I would trust to hold up a 65 inch TV that has cost hundreds of pounds, as even th
