Electrical Videos
In this section you will find videos to help you when doing home electrics.
If you are not 100% certain what you are doing please consult a professional electrician.
  • 04:35 Popular wago compact connectors
    by Admin Added 2,337 Views / 1 Likes
    Wago compact connectors can make DIY electrics and professional installation work much easier, this video shows how to use them.
  • 05:07 Popular Continuity test using a multi meter
    by Admin Added 2,318 Views / 0 Likes
    How to use a multi-meter to perform a continuity test.
  • 07:39 Popular How to install a USB wall socket
    by Admin Added 2,067 Views / 0 Likes
    More and more electrical items can now be charged using a USB lead, which often means plugging an adapter into a standard electrical socket. This can mean that your socket soon becomes busy with items that are trying to use the power outlets. Installing a
  • 03:16 Popular multimeter voltage using a multi meter
    by Admin Added 2,057 Views / 0 Likes
    How to use a multi-meter to measure voltage
  • 02:34 Popular How to cut a socket screw or machine screw
    by Admin Added 1,911 Views / 1 Likes
    How to cut an electrical screw or machine screw using a pair of electricians pliers.
  • 06:21 Popular Cat 5 network cable crimping
    by Admin Added 1,896 Views / 2 Likes
    If you are installing a home network or simply want to make up your own patch leads this video will show how to crimp an RJ45 plug on to the end of a CAT 5 network cable There are two standards when wiring up network cables, T568A and T568B this requires
  • 04:15 Popular How to rewire a fuse
    by Admin Added 1,884 Views / 0 Likes
    How to rewire a fuse from a consumer unit, this is useful if you have an older style consumer unit.
  • 04:35 Popular Wagobox
    Wagobox
    by Admin Added 1,796 Views / 0 Likes
    The wagobox is very handy when joining cables as it can be used in dificult to reach locations as long as wago connectors are used
  • 03:46 Popular how to fit a back box in plasterboard
    by Admin Added 1,683 Views / 0 Likes
    How to fit a dry lining back box in a plasterboard wall.
  • 06:32 Popular Wiring a three pin plug
    by Admin Added 1,618 Views / 0 Likes
    How to wire a standard 3 pin plug
  • 03:02 Popular Energy saving Light bulbs
    by Admin Added 1,530 Views / 0 Likes
    Year on year electricity bills increase at a much higher rate than inflation. By installing low energy light bulbs you can make a substantial saving on your energy bills in a quick time. Typically payback is after 12 months, by that time you have paid for
  • 05:19 Popular How to measure amperage
    by Admin Added 1,461 Views / 0 Likes
    How to measure amperage using a multi-meter
  • 03:42 Popular Fuse Testing
    Fuse Testing
    by Admin Added 1,411 Views / 0 Likes
    How to check a fuse using a couple of different tools
  • 06:26 Popular How to install a dimmer switch
    by Admin Added 1,328 Views / 1 Likes
    This video shows how to replace a standard light switch with a dimmer switch. Dimmer switches are popular because the light in the room can be dimmed to make the room lighting less bright. Before installing a dimmer switch you have to be certain that the
  • 12:33 Popular How to replace a single socket with a double socket
    by Admin Added 952 Views / 1 Likes
    This video shows how to replace a standard UK single domestic socket with a double socket. Single sockets are often not suitable for today’s power hungry households which mean that some people buy unsafe adaptors that put undue stress on the sockets
  • 09:14 Popular How to install a Wi-Fi extender socket
    by Admin Added 636 Views / 0 Likes
    In this video I replace a standard double switched electrical socket with a British General 922UWR Wi-Fi extender socket, these are a great idea as they allow you to use both socket outlets whilst extending the Wi-Fi network. Visit the British General web
