Electrical Videos
In this section you will find videos to help you when doing home electrics.
If you are not 100% certain what you are doing please consult a professional electrician.
  • 04:15 Popular How to rewire a fuse
    by Admin Added 1,884 Views / 0 Likes
    How to rewire a fuse from a consumer unit, this is useful if you have an older style consumer unit.
  • 03:10 Popular How to strip electrical twin core and earth cable
    by Admin Added 2,637 Views / 0 Likes
    Twin core and earth cable can easily be striped ready for termination using this method
  • 08:20 Popular How to wire a ceiling light
    by Admin Added 7,813 Views / 4 Likes
    Fitting a new ceiling light is never as easy as people think, this videos shows how to do it
  • 13:35 Popular How to wire a two way light switch | two way switching
    by Admin Added 12.2k Views / 8 Likes
    This video shows how to convert a typical one way light switch into a two way switching arrangement. This means that a light (or lights) can be switched off from two locations. You can also add a third light switch if you use an intermediate light switch,
  • 02:46 Popular In-Line wire connectors- Spliceline
    by Admin Added 2,700 Views / 0 Likes
    SpliceLine™ in-line connectors are one of the easiest ways of joining two wires together without an specialised tools such as crimping pliers. SpliceLine™ In-Line connectors are very compact and are probably theeasiest way of joining two wires
  • 02:43 Popular Light switch testing
    by Admin Added 2,691 Views / 0 Likes
    This video is useful if you are having problems with a light that either will not switch off or will not switch on (assuming the lamp has been checked).
  • 03:16 Popular multimeter voltage using a multi meter
    by Admin Added 2,058 Views / 0 Likes
    How to use a multi-meter to measure voltage
  • 08:39 Popular Replacing a light switch
    by Admin Added 3,039 Views / 0 Likes
    How to replace a light switch
  • 11:00 Popular Replacing an electrical socket
    by Admin Added 2,724 Views / 0 Likes
    by Admin Added 2,768 Views / 1 Likes
  • 16:41 Popular Sinking an electrical backbox
    by Admin Added 4,455 Views / 0 Likes
    How to fit an electrical double back box onto a solid brick wall that has been wallpapered. Fitting a back box is normally done before the wall is papered but if you wanted to add an extra socket in your home and the wall has been papered then this video
  • 07:03 Popular Two way light switching explained
    by Admin Added 6,783 Views / 5 Likes
    This video shows how to wire a two way switching circuit, or a two way lighting circuit. I believe this is called a three way switching circuit in some countries. This video shows how to change a one way lighting circuit into a two way lighting circuit an
  • 04:35 Popular wago compact connectors
    by Admin Added 2,339 Views / 1 Likes
    Wago compact connectors can make DIY electrics and professional installation work much easier, this video shows how to use them.
  • 04:17 Popular Wago lighting connectors
    by Admin Added 2,544 Views / 0 Likes
    Wago lighting connector make replacing a light fitting much easier
  • 04:35 Popular Wagobox
    Wagobox
    by Admin Added 1,801 Views / 0 Likes
    The wagobox is very handy when joining cables as it can be used in dificult to reach locations as long as wago connectors are used
  • 06:32 Popular Wiring a three pin plug
    by Admin Added 1,618 Views / 0 Likes
    How to wire a standard 3 pin plug
