Electrical Videos
In this section you will find videos to help you when doing home electrics.
If you are not 100% certain what you are doing please consult a professional electrician.
  • 13:35 Popular How to wire a two way light switch | two way switching
    by Admin Added 12.1k Views / 8 Likes
    This video shows how to convert a typical one way light switch into a two way switching arrangement. This means that a light (or lights) can be switched off from two locations. You can also add a third light switch if you use an intermediate light switch,
  • 09:54 Popular How to identify the switched live wire
    by Admin Added 11.2k Views / 5 Likes
    Identifying the switched live wire at a ceiling rose can be difficult especially if the old ceiling rose has been removed, this video shows how to identify it using a multi meter
  • 08:20 Popular How to wire a ceiling light
    by Admin Added 7,752 Views / 3 Likes
    Fitting a new ceiling light is never as easy as people think, this videos shows how to do it
  • 07:03 Popular Two way light switching explained
    by Admin Added 6,450 Views / 4 Likes
    This video shows how to wire a two way switching circuit, or a two way lighting circuit. I believe this is called a three way switching circuit in some countries. This video shows how to change a one way lighting circuit into a two way lighting circuit an
  • 16:41 Popular Sinking an electrical backbox
    by Admin Added 4,440 Views / 0 Likes
    How to fit an electrical double back box onto a solid brick wall that has been wallpapered. Fitting a back box is normally done before the wall is papered but if you wanted to add an extra socket in your home and the wall has been papered then this video
  • 11:39 Popular How to install a Fused connection unit | FCU
    by Admin Added 3,343 Views / 0 Likes
    This video shows a DIY'er how to install a fused connection unit, often called a FCU. Useful links-http://www.ultimatehandyman.co.uk/routing_a_cable.htm#The latest requirements for running cables is below-http://www.ultimatehandyman.co.uk/forum1/diy-elect
  • 10:49 Popular How to replace wall lights | fitting uplighters
    by Admin Added 3,323 Views / 0 Likes
    This video shows how to safely replace wall lights and has some good tips on collecting the dust when drilling as well as how to ensure the fixing bracket is completely level.
  • 08:39 Popular Replacing a light switch
    by Admin Added 3,022 Views / 0 Likes
    How to replace a light switch
    by Admin Added 2,740 Views / 1 Likes
  • 11:00 Popular Replacing an electrical socket
    by Admin Added 2,705 Views / 0 Likes
  • 02:46 Popular In-Line wire connectors- Spliceline
    by Admin Added 2,677 Views / 0 Likes
    SpliceLine™ in-line connectors are one of the easiest ways of joining two wires together without an specialised tools such as crimping pliers. SpliceLine™ In-Line connectors are very compact and are probably theeasiest way of joining two wires
  • 02:43 Popular Light switch testing
    by Admin Added 2,660 Views / 0 Likes
    This video is useful if you are having problems with a light that either will not switch off or will not switch on (assuming the lamp has been checked).
  • 03:10 Popular How to strip electrical twin core and earth cable
    by Admin Added 2,626 Views / 0 Likes
    Twin core and earth cable can easily be striped ready for termination using this method
  • 04:17 Popular Wago lighting connectors
    by Admin Added 2,536 Views / 0 Likes
    Wago lighting connector make replacing a light fitting much easier
  • 11:00 Popular How to install Trace heating
    by Admin Added 2,488 Views / 1 Likes
    Trace heating is useful for preventing pipes freezing in winter months. This kit is connected to a thermostat so that the trace heater only switches on when the temperature drops below 5 degrees C. If you constantly get frozen pipes in winter then a trace
  • 02:06 Popular How to replace a lamp in a downlighter
    by Admin Added 2,347 Views / 0 Likes
    How to replace a downlighter lamp or a halogen lamp in a spotlight.
