Electrical Videos
In this section you will find videos to help you when doing home electrics.
If you are not 100% certain what you are doing please consult a professional electrician.
  • 13:35 Popular How to wire a two way light switch | two way switching
    by Admin Added 13.3k Views / 8 Likes
    This video shows how to convert a typical one way light switch into a two way switching arrangement. This means that a light (or lights) can be switched off from two locations. You can also add a third light switch if you use an intermediate light switch,
  • 09:54 Popular How to identify the switched live wire
    by Admin Added 12.3k Views / 7 Likes
    Identifying the switched live wire at a ceiling rose can be difficult especially if the old ceiling rose has been removed, this video shows how to identify it using a multi meter
  • 07:03 Popular Two way light switching explained
    by Admin Added 7,969 Views / 6 Likes
    This video shows how to wire a two way switching circuit, or a two way lighting circuit. I believe this is called a three way switching circuit in some countries. This video shows how to change a one way lighting circuit into a two way lighting circuit an
  • 08:20 Popular How to wire a ceiling light
    by Admin Added 8,194 Views / 4 Likes
    Fitting a new ceiling light is never as easy as people think, this videos shows how to do it
  • 06:21 Popular Cat 5 network cable crimping
    by Admin Added 1,986 Views / 2 Likes
    If you are installing a home network or simply want to make up your own patch leads this video will show how to crimp an RJ45 plug on to the end of a CAT 5 network cable There are two standards when wiring up network cables, T568A and T568B this requires
  • 02:34 Popular How to cut a socket screw or machine screw
    by Admin Added 1,974 Views / 1 Likes
    How to cut an electrical screw or machine screw using a pair of electricians pliers.
  • 06:26 Popular How to install a dimmer switch
    by Admin Added 1,433 Views / 1 Likes
    This video shows how to replace a standard light switch with a dimmer switch. Dimmer switches are popular because the light in the room can be dimmed to make the room lighting less bright. Before installing a dimmer switch you have to be certain that the
  • 12:33 Popular How to replace a single socket with a double socket
    by Admin Added 1,085 Views / 1 Likes
    This video shows how to replace a standard UK single domestic socket with a double socket. Single sockets are often not suitable for today’s power hungry households which mean that some people buy unsafe adaptors that put undue stress on the sockets
    by Admin Added 2,893 Views / 1 Likes
  • 04:35 Popular wago compact connectors
    by Admin Added 2,427 Views / 1 Likes
    Wago compact connectors can make DIY electrics and professional installation work much easier, this video shows how to use them.
  • 11:00 Popular How to install Trace heating
    by Admin Added 2,597 Views / 1 Likes
    Trace heating is useful for preventing pipes freezing in winter months. This kit is connected to a thermostat so that the trace heater only switches on when the temperature drops below 5 degrees C. If you constantly get frozen pipes in winter then a trace
  • 07:39 Popular How to install a USB wall socket
    by Admin Added 2,194 Views / 0 Likes
    More and more electrical items can now be charged using a USB lead, which often means plugging an adapter into a standard electrical socket. This can mean that your socket soon becomes busy with items that are trying to use the power outlets. Installing a
  • 11:00 Popular Replacing an electrical socket
    by Admin Added 2,820 Views / 0 Likes
  • 02:13 How to convert a European plug to a UK plug | two pin plug to three pin plug
    by Admin Added 64 Views / 0 Likes
    This video shows How to convert a European plug to a UK plug, this is very easy to do and the convertor plugs only cost about £2 Converting a two-pin plug to three pin plug has never been easier. Remember if you cut off the two pin plug and wire it
  • 08:39 Popular Replacing a light switch
    by Admin Added 3,150 Views / 0 Likes
    How to replace a light switch
  • 04:35 Popular Wagobox
    Wagobox
    by Admin Added 1,889 Views / 0 Likes
    The wagobox is very handy when joining cables as it can be used in dificult to reach locations as long as wago connectors are used
