Drilling videos
Drilling is one of the most common things done when doing DIY, for that reason a drill is one of the most widely used power tools in the world. This section has all the drilling videos you will ever need including videos on how to drill wood, metal, plastics and masonry.
  • 07:08 Popular Bosch multi construction drill bit
    by Admin Added 1,563 Views / 1 Likes
    Bosch multi construction drill bit are tested, these drills can be used on wood, metal, masonry and tiles.
    by Admin Added 1,549 Views / 1 Likes
  • 03:55 Popular Drill bits for drilling metal
    by Admin Added 1,547 Views / 0 Likes
    Metal drill types, this video is one of three on drilling metal.
  • 05:34 Popular Blacksmiths drills
    Blacksmiths drills
    by Admin Added 1,393 Views / 0 Likes
    When drilling metal you are often restricted by the size of the drill’s chuck but by using reduced shank drill bits, often called Blacksmiths drill bits you can easily drill larger holes as long as your drill has sufficient power.
  • 05:41 Popular Cutting holes in metal using a hole saw
    by Admin Added 1,210 Views / 0 Likes
    Cutting holes in metal can be difficult, here we show the correct technique for doing this using a cordless drill with torque control and a good quality hole saw
  • 02:46 Popular Diamond coated hole saws
    by Admin Added 1,095 Views / 0 Likes
    Diamond coated hole saws can be used to make large holes in even the toughest of tiles
  • 04:03 How to drill a hole through tungsten carbide
    by Admin Added 49 Views / 0 Likes
    Tungsten carbide is one of the worlds toughest metals, it is impossible to drill using traditional drill bits. In this video a JCB diamond tech hole saw is used in order to drill through some 6mm or 1/4-inch-thick tungsten carbide. In a previous video I d
