Drilling videos
Drilling is one of the most common things done when doing DIY, for that reason a drill is one of the most widely used power tools in the world. This section has all the drilling videos you will ever need including videos on how to drill wood, metal, plastics and masonry.
  • 07:15 Popular How to use a diamond core drill
    by Admin Added 3,157 Views / 0 Likes
    How to use a diamond core drill to drill a large diameter hole through a solid wall.
  • 04:44 Popular Cobalt drill bits
    Cobalt drill bits
    by Admin Added 2,015 Views / 0 Likes
    Cobalt drills are excellent at drilling through hard metals, they can often drill tough metals that a normal High speed steel drill bit cannot drill.
  • 01:01 Popular Tips when drilling into a wall
    by Admin Added 2,651 Views / 0 Likes
    Here are a few tips for drilling into a wall
  • 03:06 Popular Drilling through cavity walls
    by Admin Added 2,726 Views / 0 Likes
    This video demonstrates how to drill through a cavity wall
  • 03:55 Popular Drill bits for drilling metal
    by Admin Added 1,601 Views / 0 Likes
    Metal drill types, this video is one of three on drilling metal.
  • 02:39 Popular How to drill ceramic tiles
    by Admin Added 1,738 Views / 0 Likes
    Drilling ceramic tiles is normally very easy as they are soft compared to porcelain
  • 05:34 Popular Blacksmiths drills
    Blacksmiths drills
    by Admin Added 1,437 Views / 0 Likes
    When drilling metal you are often restricted by the size of the drill’s chuck but by using reduced shank drill bits, often called Blacksmiths drill bits you can easily drill larger holes as long as your drill has sufficient power.
