Drilling videos
Drilling is one of the most common things done when doing DIY, for that reason a drill is one of the most widely used power tools in the world. This section has all the drilling videos you will ever need including videos on how to drill wood, metal, plastics and masonry.
  • 05:34 Popular Blacksmiths drills
    Blacksmiths drills
    by Admin Added 1,397 Views / 0 Likes
    When drilling metal you are often restricted by the size of the drill’s chuck but by using reduced shank drill bits, often called Blacksmiths drill bits you can easily drill larger holes as long as your drill has sufficient power.
  • 07:08 Popular Bosch multi construction drill bit
    by Admin Added 1,567 Views / 1 Likes
    Bosch multi construction drill bit are tested, these drills can be used on wood, metal, masonry and tiles.
  • 04:44 Popular Cobalt drill bits
    Cobalt drill bits
    by Admin Added 1,977 Views / 0 Likes
    Cobalt drills are excellent at drilling through hard metals, they can often drill tough metals that a normal High speed steel drill bit cannot drill.
  • 05:41 Popular Cutting holes in metal using a hole saw
    by Admin Added 1,218 Views / 0 Likes
    Cutting holes in metal can be difficult, here we show the correct technique for doing this using a cordless drill with torque control and a good quality hole saw
    by Admin Added 1,554 Views / 1 Likes
  • 02:46 Popular Diamond coated hole saws
    by Admin Added 1,097 Views / 0 Likes
    Diamond coated hole saws can be used to make large holes in even the toughest of tiles
  • 03:55 Popular Drill bits for drilling metal
    by Admin Added 1,552 Views / 0 Likes
    Metal drill types, this video is one of three on drilling metal.
  • 01:46 Popular Drill holes in a ceiling without the dust
    by Admin Added 2,085 Views / 1 Likes
    This video shows how you can use a take away container that would normally be thrown away to catch the dust when drilling holes in a plasterboard ceiling, using a hole saw.
  • 07:12 Popular drill metal with a  pillar drill
    by Admin Added 2,333 Views / 0 Likes
    drill metal using a pillar drill
  • 07:12 Popular Drilling metal
    Drilling metal
    by Admin Added 1,696 Views / 0 Likes
    Drilling metal is not too difficult as long as you use the correct equipment. Here we showhow to drill steel using a hand drill and HSS drill bit.
  • 03:06 Popular Drilling through cavity walls
    by Admin Added 2,659 Views / 0 Likes
    This video demonstrates how to drill through a cavity wall
  • 00:56 Popular Hammer drill versus SDS drill
    by Admin Added 2,659 Views / 1 Likes
    Apart from the chuck an SDS machine is far more powerful for drilling masonry due to the built in pneumatic hammer as this video demonstrates
  • 04:03 How to drill a hole through tungsten carbide
    by Admin Added 61 Views / 0 Likes
    Tungsten carbide is one of the worlds toughest metals, it is impossible to drill using traditional drill bits. In this video a JCB diamond tech hole saw is used in order to drill through some 6mm or 1/4-inch-thick tungsten carbide. In a previous video I d
  • 04:40 Popular How to drill Acrylic
    by Admin Added 2,356 Views / 1 Likes
    Acrylic sheet such as Perspex, Lucite or Plexiglas can be drilled using drill bits that are designed for use on metal. A sharp metal drilling bit will easily break the acrylic when it exits the work piece and so a blunt drill bit is preferred, or the shar
  • 02:39 Popular How to drill ceramic tiles
    by Admin Added 1,709 Views / 0 Likes
    Drilling ceramic tiles is normally very easy as they are soft compared to porcelain
  • 04:00 Popular How to drill porcelain tiles
    by Admin Added 1,885 Views / 0 Likes
    Porcelain tiles are tough and difficult to drill. Here we show how to drill them
