Drilling videos
Drilling is one of the most common things done when doing DIY, for that reason a drill is one of the most widely used power tools in the world. This section has all the drilling videos you will ever need including videos on how to drill wood, metal, plastics and masonry.
    by Admin Added 1,522 Views / 1 Likes
  • 04:40 Popular How to drill Acrylic
    by Admin Added 2,301 Views / 1 Likes
    Acrylic sheet such as Perspex, Lucite or Plexiglas can be drilled using drill bits that are designed for use on metal. A sharp metal drilling bit will easily break the acrylic when it exits the work piece and so a blunt drill bit is preferred, or the shar
  • 01:46 Popular Drill holes in a ceiling without the dust
    by Admin Added 2,052 Views / 1 Likes
    This video shows how you can use a take away container that would normally be thrown away to catch the dust when drilling holes in a plasterboard ceiling, using a hole saw.
  • 03:05 Popular How to use holesaws
    How to use holesaws
    by Admin Added 1,543 Views / 1 Likes
    How to use holesaws to cut out large holes from wood, plastic or metal.
  • 07:08 Popular Bosch multi construction drill bit
    by Admin Added 1,535 Views / 1 Likes
    Bosch multi construction drill bit are tested, these drills can be used on wood, metal, masonry and tiles.
  • 08:32 Popular How to use a cordless drill driver
    by Admin Added 1,731 Views / 1 Likes
    Cordless drill drivers are now extremely common but unfortunately many people cannot use them to their full potential. In this video I show how to use all of the features of the Dewalt 18v cordless combination drill, including torque control which is very
  • 04:11 Popular Left handed drill bit to remove broken studs
    by Admin Added 1,786 Views / 1 Likes
    Removing a broken bolt or stud can be extremely difficult but in some cases such as when the bolt head has been sheared off by sideways force it is possible to remove the remainder of the bolt using a left handed drill bit. Here we demonstrate how to remo
  • 07:12 Popular Drilling metal
    Drilling metal
    by Admin Added 1,663 Views / 0 Likes
    Drilling metal is not too difficult as long as you use the correct equipment. Here we showhow to drill steel using a hand drill and HSS drill bit.
  • 04:00 Popular How to drill porcelain tiles
    by Admin Added 1,854 Views / 0 Likes
    Porcelain tiles are tough and difficult to drill. Here we show how to drill them
  • 02:31 Popular How to use hinge drills
    by Admin Added 2,291 Views / 0 Likes
    Hinge drills or hinge siting drills are a very useful drill for ensuring that the screw pilot hole is drilled in the dead centre of the hinge fixing hole. Please ensure that you do not buy a cheap set of these as they will not work as well as a decent qua
  • 07:12 Popular drill metal with a  pillar drill
    by Admin Added 2,270 Views / 0 Likes
    drill metal using a pillar drill
  • 00:56 Popular Hammer drill versus SDS drill
    by Admin Added 2,570 Views / 1 Likes
    Apart from the chuck an SDS machine is far more powerful for drilling masonry due to the built in pneumatic hammer as this video demonstrates
  • 02:30 Popular How to enlarge a hole saw or core drill hole
    by Admin Added 1,802 Views / 0 Likes
    Once a hole has been cut using a core drill or holesaw it is difficult to enlarge the hole, but here I demonstrate an easy way to acheive this.
  • 02:46 Popular Diamond coated hole saws
    by Admin Added 1,082 Views / 0 Likes
    Diamond coated hole saws can be used to make large holes in even the toughest of tiles
  • 05:41 Popular Cutting holes in metal using a hole saw
    by Admin Added 1,179 Views / 0 Likes
    Cutting holes in metal can be difficult, here we show the correct technique for doing this using a cordless drill with torque control and a good quality hole saw
  • 07:15 Popular How to use a diamond core drill
    by Admin Added 2,989 Views / 0 Likes
    How to use a diamond core drill to drill a large diameter hole through a solid wall.
