Bathroom replacement videos
This section has a selection of videos showing how to remove and replace a complete bathroom.
Replacing a bathroom can be difficult especially if you only have one bathroom in the home, but this section has videos showing how to completely replace a whole bathroom including the basin, bath, shower and toilet.
  • 15:27 Popular Bathroom ceiling cladding
    by Admin Added 2,790 Views / 1 Likes
    How to clad a bathroom ceiling using PVC cladding.
  • 02:35 Popular How to remove a toilet pan
    by Admin Added 2,747 Views / 0 Likes
    Removing the toilet pan is necessary so that the floor can be over boarded and tiled, here we show how to remove the pan.
  • 04:11 Popular How to remove tiles
    How to remove tiles
    by Admin Added 2,703 Views / 1 Likes
    Removing tiles can be tricky, it is best to take a methodical approach rather than going at it like a bull in a china shop. Here we remove wall tiles using a knock through screwdriver and hammer.
  • 08:05 Popular Shower tray install on mortar
    by Admin Added 2,702 Views / 3 Likes
    Many shower trays require installing onto a bed of mortar (cement), this video shows how to install such a shower tray onto a wooden floor.
  • 05:15 Popular How to install a shower waste trap
    by Admin Added 2,686 Views / 0 Likes
    This video shows how to install a McAlpine waste trap to a quadrant shower tray.
  • 03:54 Popular Fitting a wall mounted tap
    by Admin Added 2,616 Views / 0 Likes
    Here we fit a wall mounted tap/shower mixer to a wall.
  • 02:37 Popular How to remove a toilet cistern
    by Admin Added 2,575 Views / 0 Likes
    To remove the tiles from the back of the toilet you often need to remove the cistern. The toilet pan can be left in position which means that you can still flush the toilet by using a bucket of water if necessary.
  • 05:26 Popular How to batten a ceiling
    by Admin Added 2,530 Views / 0 Likes
    Battening a ceiling is often required if the ceiling is to be clad. Tongue and groove cladding can be used or special PVC cladding that is designed for use in bathrooms. The important bit is getting the battens level and secure.
  • 03:35 Popular Removing plaster with a SDS drill
    Removing plaster from walls can be done using a bolster chisel and hammer, but it is much easier with a SDS drill that has a roto stop function and a suitable chisel.
  • 03:49 Popular How to move a waste pipe
    by Admin Added 2,499 Views / 0 Likes
    When refitting a bathroom it may be necessary to move some of the services such as the waste pipes. Here we show how to move them, it is important to do this before tiling the floor or ply lining the floor.
  • 15:10 Popular How to plumb in a wall mounted tap or shower mixer
    by Admin Added 2,389 Views / 2 Likes
    This video shows how to plumb in a wall mounted tap or a shower mixer, this includes fitting isolation valves and double check valves.
  • 04:22 Popular Foam fix plasterboard
    by Admin Added 2,062 Views / 1 Likes
    Plasterboard fixing foam is a quicker and cleaner solution than using dry wall adhesive. Sometimes it is easy to use and sometimes it is more difficult as in this example
  • 01:55 Popular How to remove a bath
    by Admin Added 2,004 Views / 0 Likes
    This video shows how to remove a bath. Once the tiling has been completed a new bath will be fitted. Brought to you by Brought to you by http://www.ultimatehandyman.co.uk/forum1/
  • 03:43 Popular How to remove coving
    by Admin Added 1,946 Views / 0 Likes
    Coving is not always in fashion and can spoil the look of a room. Here we show a quick way to remove the coving using a knock through screwdriver and a hammer.
  • 05:01 Popular How to remove a basin
    by Admin Added 1,583 Views / 0 Likes
    In order to remove all of the tiles from the wall we need to remove the basin. This video shows how to remove a basin. Brought to you by http://www.ultimatehandyman.co.uk/forum1/
