Bathroom replacement videos
This section has a selection of videos showing how to remove and replace a complete bathroom.
Replacing a bathroom can be difficult especially if you only have one bathroom in the home, but this section has videos showing how to completely replace a whole bathroom including the basin, bath, shower and toilet.
  • 04:14 Popular How to Ply line a floor
    by Admin Added 3,231 Views / 1 Likes
    Before tiling a floor it is often necessary to strengthen the floor using a sheet material such as WBP plywood or tile backer board. This video demonstrates how to fix WBP plywood to a tongue and groove wooden floor.
  • 05:01 Popular How to remove a basin
    by Admin Added 1,543 Views / 0 Likes
    In order to remove all of the tiles from the wall we need to remove the basin. This video shows how to remove a basin. Brought to you by http://www.ultimatehandyman.co.uk/forum1/
  • 01:55 Popular How to remove a bath
    by Admin Added 1,967 Views / 0 Likes
    This video shows how to remove a bath. Once the tiling has been completed a new bath will be fitted. Brought to you by Brought to you by http://www.ultimatehandyman.co.uk/forum1/
  • 02:37 Popular How to remove a toilet cistern
    by Admin Added 2,540 Views / 0 Likes
    To remove the tiles from the back of the toilet you often need to remove the cistern. The toilet pan can be left in position which means that you can still flush the toilet by using a bucket of water if necessary.
  • 02:35 Popular How to remove a toilet pan
    by Admin Added 2,688 Views / 0 Likes
    Removing the toilet pan is necessary so that the floor can be over boarded and tiled, here we show how to remove the pan.
  • 03:43 Popular How to remove coving
    by Admin Added 1,923 Views / 0 Likes
    Coving is not always in fashion and can spoil the look of a room. Here we show a quick way to remove the coving using a knock through screwdriver and a hammer.
  • 04:11 Popular How to remove tiles
    How to remove tiles
    by Admin Added 2,677 Views / 1 Likes
    Removing tiles can be tricky, it is best to take a methodical approach rather than going at it like a bull in a china shop. Here we remove wall tiles using a knock through screwdriver and hammer.
  • 04:59 Popular How to replace a bathroom
    by Admin Added 4,129 Views / 0 Likes
    This video is the first in a series of videos that shows how to replace a bathroom from start to finish. This is a large job and is probably one of the largest jobs that a DIY'er will undertake in their own home. Please check the playlist for all other vi
  • 19:55 Popular How to tile a bathroom
    by Admin Added 4,129 Views / 1 Likes
    This video shows how to tile a wall and make the all important scribe cuts. Wall tiling is often difficult and can be time consuming. Hopefully this video will help people when they are wall tiling.
  • 06:55 Popular Installing tile trim on a out of level wall
    by Admin Added 3,293 Views / 0 Likes
    Here a tile trim is fitted to a wall that is not straight, this can be difficult to overcome and so a workaround solution is demonstrated.
  • 03:35 Popular Removing plaster with a SDS drill
    by Admin Added 2,466 Views / 0 Likes
    Removing plaster from walls can be done using a bolster chisel and hammer, but it is much easier with a SDS drill that has a roto stop function and a suitable chisel.
  • 08:05 Popular Shower tray install on mortar
    by Admin Added 2,632 Views / 3 Likes
    Many shower trays require installing onto a bed of mortar (cement), this video shows how to install such a shower tray onto a wooden floor.
  • 14:32 Popular Tanking a shower area
    by Admin Added 2,799 Views / 1 Likes
    Tanking a shower area is always a good idea as water eventually gets behind tiles causing the plasterboard to perish.
  • 04:47 Popular Tiling around pipe entries
    by Admin Added 3,642 Views / 1 Likes
    How to tile around pipe entries, this is useful if you are fitting a wall mounted tap etc.
  • 09:57 Popular where to start tiling
    by Admin Added 3,460 Views / 1 Likes
    This video shows how to determine the best place to start tiling a wall. It is important that the correct starting position is determined as you need to avoid getting in a situation where you need to cut thin slivers of tiles as it is almost impossible to
