Bathroom replacement videos
This section has a selection of videos showing how to remove and replace a complete bathroom.
Replacing a bathroom can be difficult especially if you only have one bathroom in the home, but this section has videos showing how to completely replace a whole bathroom including the basin, bath, shower and toilet.
  • 02:35 Popular How to remove a toilet pan
    by Admin Added 2,659 Views / 0 Likes
    Removing the toilet pan is necessary so that the floor can be over boarded and tiled, here we show how to remove the pan.
  • 05:32 Popular How to install a basin waste
    by Admin Added 4,575 Views / 1 Likes
    Installing a basin waste can be difficult especially if you try to use the sealing washers that are supplied with the basin waste. Here we fit a pop up waste into a square vanity unit basin.
  • 03:43 Popular How to remove coving
    by Admin Added 1,912 Views / 0 Likes
    Coving is not always in fashion and can spoil the look of a room. Here we show a quick way to remove the coving using a knock through screwdriver and a hammer.
  • 03:54 Popular Fitting a wall mounted tap
    by Admin Added 2,550 Views / 0 Likes
    Here we fit a wall mounted tap/shower mixer to a wall.
  • 05:01 Popular How to remove a basin
    by Admin Added 1,529 Views / 0 Likes
    In order to remove all of the tiles from the wall we need to remove the basin. This video shows how to remove a basin. Brought to you by http://www.ultimatehandyman.co.uk/forum1/
  • 05:26 Popular How to batten a ceiling
    by Admin Added 2,492 Views / 0 Likes
    Battening a ceiling is often required if the ceiling is to be clad. Tongue and groove cladding can be used or special PVC cladding that is designed for use in bathrooms. The important bit is getting the battens level and secure.
  • 09:57 Popular where to start tiling
    by Admin Added 3,443 Views / 1 Likes
    This video shows how to determine the best place to start tiling a wall. It is important that the correct starting position is determined as you need to avoid getting in a situation where you need to cut thin slivers of tiles as it is almost impossible to
  • 01:55 Popular How to remove a bath
    by Admin Added 1,952 Views / 0 Likes
    This video shows how to remove a bath. Once the tiling has been completed a new bath will be fitted. Brought to you by Brought to you by http://www.ultimatehandyman.co.uk/forum1/
  • 06:55 Popular Installing tile trim on a out of level wall
    by Admin Added 3,273 Views / 0 Likes
    Here a tile trim is fitted to a wall that is not straight, this can be difficult to overcome and so a workaround solution is demonstrated.
  • 03:49 Popular How to move a waste pipe
    by Admin Added 2,443 Views / 0 Likes
    When refitting a bathroom it may be necessary to move some of the services such as the waste pipes. Here we show how to move them, it is important to do this before tiling the floor or ply lining the floor.
  • 04:59 Popular How to replace a bathroom
    by Admin Added 4,106 Views / 0 Likes
    This video is the first in a series of videos that shows how to replace a bathroom from start to finish. This is a large job and is probably one of the largest jobs that a DIY'er will undertake in their own home. Please check the playlist for all other vi
  • 03:35 Popular Removing plaster with a SDS drill
    by Admin Added 2,437 Views / 0 Likes
    Removing plaster from walls can be done using a bolster chisel and hammer, but it is much easier with a SDS drill that has a roto stop function and a suitable chisel.
  • 06:08 Popular How to install a bath waste
    by Admin Added 4,570 Views / 0 Likes
    This video shows How to install a pop up waste to an L shaped bath.
  • 02:37 Popular How to remove a toilet cistern
    by Admin Added 2,511 Views / 0 Likes
    To remove the tiles from the back of the toilet you often need to remove the cistern. The toilet pan can be left in position which means that you can still flush the toilet by using a bucket of water if necessary.
  • 05:32 Popular How to grout floor tiles
    by Admin Added 2,832 Views / 0 Likes
    Grouting floor tiles can be tricky and needs doing before you walk on the floor times if possible. This video shows how to mix the grout and then apply the grout to the gaps in the tiles.
