Bathroom replacement videos
This section has a selection of videos showing how to remove and replace a complete bathroom.
Replacing a bathroom can be difficult especially if you only have one bathroom in the home, but this section has videos showing how to completely replace a whole bathroom including the basin, bath, shower and toilet.
09:51 Popular
How silicone around a bath
Added 5,841 Views / 1 LikesIn this video we silicone around a bath This is made much more difficult as the old silicone and also a sealing strip needed removing first. After removing most of the silicone sealant a chemical was applied to remove the rest of the silicone. After the s
Featured -
03:41 Popular
Bath sealing strip | MX seal strip
Added 4,952 Views / 0 LikesBefore fitting a bath or a shower tray it is a good idea to fit a Flexi seal strip which sticks to the bath or shower tray and can be tiled on top of. This makes it impossible for any water to get behind the bath or shower tray.
06:08 Popular
How to install a bath waste
Added 4,908 Views / 1 LikesThis video shows How to install a pop up waste to an L shaped bath.
05:32 Popular
How to install a basin waste
Added 4,866 Views / 2 LikesInstalling a basin waste can be difficult especially if you try to use the sealing washers that are supplied with the basin waste. Here we fit a pop up waste into a square vanity unit basin.
12:11 Popular
Floor tiling
Added 4,788 Views / 2 LikesThis video shows how to tile a floor using rapid setting adhesive.
12:39 Popular
Added 4,535 Views / 2 LikesThis video shows how to fit an L shaped bath. It can be time consuming to fit but it is worth spending the time to get the bath in the correct position and level. Once fitted correctly and sealed correctly your bath should last for years.
04:59 Popular
How to replace a bathroom
Added 4,311 Views / 0 LikesThis video is the first in a series of videos that shows how to replace a bathroom from start to finish. This is a large job and is probably one of the largest jobs that a DIY'er will undertake in their own home. Please check the playlist for all other vi
19:55 Popular
How to tile a bathroom
Added 4,304 Views / 1 LikesThis video shows how to tile a wall and make the all important scribe cuts. Wall tiling is often difficult and can be time consuming. Hopefully this video will help people when they are wall tiling.
05:54 Popular
How to get a neat silicone line
Added 3,934 Views / 2 LikesMany people do not like applying silicone sealant, but it can be reasonably easy to apply if you use the correct technique and the correct tools. Here I demonstrate how to use the Fughi kit to get that perfect silicone line that is often so difficult to a
04:47 Popular
Tiling around pipe entries
Added 3,776 Views / 1 LikesHow to tile around pipe entries, this is useful if you are fitting a wall mounted tap etc.
09:57 Popular
where to start tiling
Added 3,672 Views / 1 LikesThis video shows how to determine the best place to start tiling a wall. It is important that the correct starting position is determined as you need to avoid getting in a situation where you need to cut thin slivers of tiles as it is almost impossible to
06:55 Popular
Installing tile trim on a out of level wall
Added 3,505 Views / 0 LikesHere a tile trim is fitted to a wall that is not straight, this can be difficult to overcome and so a workaround solution is demonstrated.
04:14 Popular
How to Ply line a floor
Added 3,353 Views / 1 LikesBefore tiling a floor it is often necessary to strengthen the floor using a sheet material such as WBP plywood or tile backer board. This video demonstrates how to fix WBP plywood to a tongue and groove wooden floor.
08:35 Popular
How to fit a shower fixing bracket
Added 3,193 Views / 3 LikesThis video shows how to fit a shower mixing bracket. Once the bracket has been fixed the bracket can then be plumbed in, then the shower bar or wall mounted tap can be fixed to it.
05:32 Popular
How to grout floor tiles
Added 2,961 Views / 0 LikesGrouting floor tiles can be tricky and needs doing before you walk on the floor times if possible. This video shows how to mix the grout and then apply the grout to the gaps in the tiles.
14:32 Popular
Tanking a shower area
Added 2,914 Views / 1 LikesTanking a shower area is always a good idea as water eventually gets behind tiles causing the plasterboard to perish.
