Bathroom replacement videos
This section has a selection of videos showing how to remove and replace a complete bathroom.
Replacing a bathroom can be difficult especially if you only have one bathroom in the home, but this section has videos showing how to completely replace a whole bathroom including the basin, bath, shower and toilet.
  • 03:41 Popular Bath sealing strip | MX seal strip
    by Admin Added 4,896 Views / 0 Likes
    Before fitting a bath or a shower tray it is a good idea to fit a Flexi seal strip which sticks to the bath or shower tray and can be tiled on top of. This makes it impossible for any water to get behind the bath or shower tray.
  • 15:27 Popular Bathroom ceiling cladding
    by Admin Added 2,871 Views / 1 Likes
    How to clad a bathroom ceiling using PVC cladding.
  • 03:54 Popular Fitting a wall mounted tap
    by Admin Added 2,714 Views / 0 Likes
    Here we fit a wall mounted tap/shower mixer to a wall.
  • 12:11 Popular Floor tiling
    Floor tiling
    by Admin Added 4,727 Views / 2 Likes
    This video shows how to tile a floor using rapid setting adhesive.
  • 04:22 Popular Foam fix plasterboard
    by Admin Added 2,115 Views / 1 Likes
    Plasterboard fixing foam is a quicker and cleaner solution than using dry wall adhesive. Sometimes it is easy to use and sometimes it is more difficult as in this example
  • 09:51 Popular How silicone around a bath
    by Admin Added 5,805 Views / 1 Likes
    In this video we silicone around a bath This is made much more difficult as the old silicone and also a sealing strip needed removing first. After removing most of the silicone sealant a chemical was applied to remove the rest of the silicone. After the s
  • 05:26 Popular How to batten a ceiling
    by Admin Added 2,587 Views / 0 Likes
    Battening a ceiling is often required if the ceiling is to be clad. Tongue and groove cladding can be used or special PVC cladding that is designed for use in bathrooms. The important bit is getting the battens level and secure.
  • 08:35 Popular How to fit a shower fixing bracket
    by Admin Added 3,168 Views / 3 Likes
    This video shows how to fit a shower mixing bracket. Once the bracket has been fixed the bracket can then be plumbed in, then the shower bar or wall mounted tap can be fixed to it.
  • 05:54 Popular How to get a neat silicone line
    by Admin Added 3,876 Views / 2 Likes
    Many people do not like applying silicone sealant, but it can be reasonably easy to apply if you use the correct technique and the correct tools. Here I demonstrate how to use the Fughi kit to get that perfect silicone line that is often so difficult to a
  • 05:32 Popular How to grout floor tiles
    by Admin Added 2,943 Views / 0 Likes
    Grouting floor tiles can be tricky and needs doing before you walk on the floor times if possible. This video shows how to mix the grout and then apply the grout to the gaps in the tiles.
  • 05:32 Popular How to install a basin waste
    by Admin Added 4,826 Views / 2 Likes
    Installing a basin waste can be difficult especially if you try to use the sealing washers that are supplied with the basin waste. Here we fit a pop up waste into a square vanity unit basin.
  • 12:39 Popular How to install a bath
    by Admin Added 4,502 Views / 2 Likes
    This video shows how to fit an L shaped bath. It can be time consuming to fit but it is worth spending the time to get the bath in the correct position and level. Once fitted correctly and sealed correctly your bath should last for years.
  • 06:08 Popular How to install a bath waste
    by Admin Added 4,851 Views / 1 Likes
    This video shows How to install a pop up waste to an L shaped bath.
  • 05:15 Popular How to install a shower waste trap
    by Admin Added 2,753 Views / 0 Likes
    This video shows how to install a McAlpine waste trap to a quadrant shower tray.
  • 03:49 Popular How to move a waste pipe
    When refitting a bathroom it may be necessary to move some of the services such as the waste pipes. Here we show how to move them, it is important to do this before tiling the floor or ply lining the floor.
  • 15:10 Popular How to plumb in a wall mounted tap or shower mixer
    by Admin Added 2,468 Views / 2 Likes
    This video shows how to plumb in a wall mounted tap or a shower mixer, this includes fitting isolation valves and double check valves.
