Bathroom replacement videos
This section has a selection of videos showing how to remove and replace a complete bathroom.
Replacing a bathroom can be difficult especially if you only have one bathroom in the home, but this section has videos showing how to completely replace a whole bathroom including the basin, bath, shower and toilet.
  • 08:35 Popular How to fit a shower fixing bracket
    by Admin Added 3,169 Views / 3 Likes
    This video shows how to fit a shower mixing bracket. Once the bracket has been fixed the bracket can then be plumbed in, then the shower bar or wall mounted tap can be fixed to it.
  • 08:05 Popular Shower tray install on mortar
    by Admin Added 2,771 Views / 3 Likes
    Many shower trays require installing onto a bed of mortar (cement), this video shows how to install such a shower tray onto a wooden floor.
  • 15:10 Popular How to plumb in a wall mounted tap or shower mixer
    by Admin Added 2,468 Views / 2 Likes
    This video shows how to plumb in a wall mounted tap or a shower mixer, this includes fitting isolation valves and double check valves.
  • 05:54 Popular How to get a neat silicone line
    by Admin Added 3,880 Views / 2 Likes
    Many people do not like applying silicone sealant, but it can be reasonably easy to apply if you use the correct technique and the correct tools. Here I demonstrate how to use the Fughi kit to get that perfect silicone line that is often so difficult to a
  • 12:39 Popular How to install a bath
    by Admin Added 4,502 Views / 2 Likes
    This video shows how to fit an L shaped bath. It can be time consuming to fit but it is worth spending the time to get the bath in the correct position and level. Once fitted correctly and sealed correctly your bath should last for years.
  • 12:11 Popular Floor tiling
    Floor tiling
    by Admin Added 4,729 Views / 2 Likes
    This video shows how to tile a floor using rapid setting adhesive.
  • 05:32 Popular How to install a basin waste
    by Admin Added 4,828 Views / 2 Likes
    Installing a basin waste can be difficult especially if you try to use the sealing washers that are supplied with the basin waste. Here we fit a pop up waste into a square vanity unit basin.
  • 14:32 Popular Tanking a shower area
    by Admin Added 2,890 Views / 1 Likes
    Tanking a shower area is always a good idea as water eventually gets behind tiles causing the plasterboard to perish.
  • 04:47 Popular Tiling around pipe entries
    by Admin Added 3,752 Views / 1 Likes
    How to tile around pipe entries, this is useful if you are fitting a wall mounted tap etc.
  • 09:51 Popular How silicone around a bath
    by Admin Added 5,808 Views / 1 Likes
    In this video we silicone around a bath This is made much more difficult as the old silicone and also a sealing strip needed removing first. After removing most of the silicone sealant a chemical was applied to remove the rest of the silicone. After the s
  • 15:27 Popular Bathroom ceiling cladding
    by Admin Added 2,871 Views / 1 Likes
    How to clad a bathroom ceiling using PVC cladding.
  • 04:11 Popular How to remove tiles
    How to remove tiles
    by Admin Added 2,768 Views / 1 Likes
    Removing tiles can be tricky, it is best to take a methodical approach rather than going at it like a bull in a china shop. Here we remove wall tiles using a knock through screwdriver and hammer.
  • 19:55 Popular How to tile a bathroom
    by Admin Added 4,280 Views / 1 Likes
    This video shows how to tile a wall and make the all important scribe cuts. Wall tiling is often difficult and can be time consuming. Hopefully this video will help people when they are wall tiling.
  • 06:08 Popular How to install a bath waste
    by Admin Added 4,853 Views / 1 Likes
    This video shows How to install a pop up waste to an L shaped bath.
  • 04:14 Popular How to Ply line a floor
    by Admin Added 3,337 Views / 1 Likes
    Before tiling a floor it is often necessary to strengthen the floor using a sheet material such as WBP plywood or tile backer board. This video demonstrates how to fix WBP plywood to a tongue and groove wooden floor.
  • 04:22 Popular Foam fix plasterboard
    by Admin Added 2,115 Views / 1 Likes
    Plasterboard fixing foam is a quicker and cleaner solution than using dry wall adhesive. Sometimes it is easy to use and sometimes it is more difficult as in this example
