Tool videos
Tools are as necessary to a man as handbags are to women, you simply cannot have enough tools!
This section shows how to use some basic tools and also describes what some more obscure and less well known tools are used for.
  • 02:33 Popular Pipe squeeze off tool
    by Admin Added 1,463 Views / 0 Likes
    Pipe squeeze off tools are used by water and utility companies to squeeze the incoming water supply pipe closed when changing the main stop cock to the property. Smaller versions are also available for squeezing the flexible brake pipes on vehicles when r
  • 05:53 Popular SDS drills explained
    by Admin Added 1,461 Views / 0 Likes
    SDS drills are the ideal drill for drilling concrete or masonry. These drills come in both corded and cordless versions, with some of the cordless machines having almost the same power as the smaller corded versions. SDS drills are available from 12v cord
  • 01:53 Popular How to use a bell punch
    by Admin Added 1,437 Views / 0 Likes
    A bell punch is designed for centre punching the exact centre of a round bar. This inexpensive tool is very useful and is often called a bell centre punch. Marking the exact centre of a round bar has never been so easy !
  • 05:40 Popular Spirit level tutorial
    by Admin Added 1,406 Views / 0 Likes
    A spirit level is very useful when doing a wide variety of DIY projects from wallpapering to installing decking. This video shows how to use a spirit level in normal use and also how to use a level to calculate a fall when installing decking.
  • 01:08 Popular DURA-INK 5 fine Tip marker
    by Admin Added 1,143 Views / 1 Likes
    The Dura-ink Extended tip marker is very useful for marking through holes that a normal marker will not fit through.
  • 04:11 Popular Speedtaps | tapping holes with an impact wrench!
    by Admin Added 1,137 Views / 0 Likes
    Speedtaps are a very fast way to tap drilled holes. The speedtaps are made from M2 steel and nitrate coated to make them extremely tough. The hexagonal heads on the speedtaps correspond with the head on the bolt so you use the same socket for the speedtap
  • 07:57 Popular How to use a hacksaw
    by Admin Added 1,065 Views / 1 Likes
    A hacksaw is a very handy tool when working with metal or plastics and is a cheap way to cut these materials. This video shows how to fit the blade and cut metal using a hacksaw.
  • 02:24 Popular Slogging spanner | slammer wrench
    by Admin Added 1,065 Views / 0 Likes
    Slogging spanners are ideal for tightening or undoing very tight fasteners. There are not many fasteners that a slogging spanner will not undo!
  • 01:40 Popular Removing staples with the Tacwise pro staple remover
    by Admin Added 939 Views / 0 Likes
  • 14:40 Popular How to use a mitre saw safely
    by Admin Added 926 Views / 0 Likes
    Mitre saws are now very common and can be picked up very inexpensively. It is however very important that these machines are used safely to avoid potential injuries to the mitre saw use. This video looks at using the sliding mitre saw in a safe manner and
  • 03:41 Popular Torque wrench demonstration
    by Admin Added 900 Views / 0 Likes
    How to use a torque wrench to set fasteners to a specific torque setting.
  • 07:38 Popular How to use a mag base drill
    by Admin Added 766 Views / 0 Likes
    This video shows how to use a mag base drill, or magnetic base drill. Magnetic base drills are widely used in all industrial and construction environments and are one of the most useful drills that you can possibly imagine. Sometimes there is no steel for
  • 04:12 Popular Cutting steel channel with the Rage 3S
    by Admin Added 584 Views / 0 Likes
    The Evolution Rage 3s 210mm has a maximum metal cutting capacity of 6mm, but in this demonstration I cut through a piece of steel channel that measures 200mm by 100mm and is roughly 10mm thick in places. It’s not recommended to cut such large pieces
  • 03:41 Popular Strap wrench – a must have tool!
    by Admin Added 215 Views / 0 Likes
    Strap wrenches are incredibly useful tools, the aluminium one in this video can be used on items ranging from about 10mm to 300mm in diameter. Strap wrenches can grip almost anything without damage and so they are useful for anything that has a surface th
  • 06:10 Popular Round bar centre finder | drill the centre of round bar
    by Admin Added 180 Views / 0 Likes
    Finding the centre of a round bar can be difficult and time consuming. In this video I use a round bar centre finder which can be purchased on ebay for less than £6 http://fave.co/2sdV94Q This enables you to find the centre of ant round bar, tube or
  • 28:01 Popular How to use an angle grinder
    by Admin Added 158 Views / 0 Likes
    This video shows you almost everything you need to know about using an angle grinder. Angle grinders are one of the most versatile power tools that you can get, but they are also potentially dangerous if used incorrectly. For people working in industry in
