Visit Thermo worx
Tool videos
Tools are as necessary to a man as handbags are to women, you simply cannot have enough tools!
This section shows how to use some basic tools and also describes what some more obscure and less well known tools are used for.
  • 28:01 How to use an angle grinder
    by Admin Added 98 Views / 0 Likes
    This video shows you almost everything you need to know about using an angle grinder. Angle grinders are one of the most versatile power tools that you can get, but they are also potentially dangerous if used incorrectly. For people working in industry in
  • 02:31 Popular How to use hinge drills
    by Admin Added 2,120 Views / 0 Likes
    Hinge drills or hinge siting drills are a very useful drill for ensuring that the screw pilot hole is drilled in the dead centre of the hinge fixing hole. Please ensure that you do not buy a cheap set of these as they will not work as well as a decent qua
  • 02:47 Popular Never buy cheap tools
    by Admin Added 2,147 Views / 2 Likes
    Cheap tools are often false economy and can make your job ten times harder. Buy cheap buy twice is a motto that is very true
  • 02:33 Popular Pipe squeeze off tool
    by Admin Added 1,444 Views / 0 Likes
    Pipe squeeze off tools are used by water and utility companies to squeeze the incoming water supply pipe closed when changing the main stop cock to the property. Smaller versions are also available for squeezing the flexible brake pipes on vehicles when r
  • 01:40 Popular Removing staples with the Tacwise pro staple remover
    by Admin Added 918 Views / 0 Likes
  • 06:10 Popular Round bar centre finder | drill the centre of round bar
    by Admin Added 121 Views / 0 Likes
    Finding the centre of a round bar can be difficult and time consuming. In this video I use a round bar centre finder which can be purchased on ebay for less than £6 This enables you to find the centre of ant round bar, tube or
  • 05:53 Popular SDS drills explained
    by Admin Added 1,441 Views / 0 Likes
    SDS drills are the ideal drill for drilling concrete or masonry. These drills come in both corded and cordless versions, with some of the cordless machines having almost the same power as the smaller corded versions. SDS drills are available from 12v cord
  • 02:24 Popular Slogging spanner | slammer wrench
    by Admin Added 1,046 Views / 0 Likes
    Slogging spanners are ideal for tightening or undoing very tight fasteners. There are not many fasteners that a slogging spanner will not undo!
  • 04:11 Popular Speedtaps | tapping holes with an impact wrench!
    by Admin Added 1,098 Views / 0 Likes
    Speedtaps are a very fast way to tap drilled holes. The speedtaps are made from M2 steel and nitrate coated to make them extremely tough. The hexagonal heads on the speedtaps correspond with the head on the bolt so you use the same socket for the speedtap
  • 05:40 Popular Spirit level tutorial
    by Admin Added 1,397 Views / 0 Likes
    A spirit level is very useful when doing a wide variety of DIY projects from wallpapering to installing decking. This video shows how to use a spirit level in normal use and also how to use a level to calculate a fall when installing decking.
  • 03:41 Popular Strap wrench – a must have tool!
    by Admin Added 135 Views / 0 Likes
    Strap wrenches are incredibly useful tools, the aluminium one in this video can be used on items ranging from about 10mm to 300mm in diameter. Strap wrenches can grip almost anything without damage and so they are useful for anything that has a surface th
  • 03:41 Popular Torque wrench demonstration
    by Admin Added 882 Views / 0 Likes
    How to use a torque wrench to set fasteners to a specific torque setting.
  • 03:42 Popular Trend Angle fix | Angle finder
    by Admin Added 2,163 Views / 0 Likes
    The trend angle fix is very useful for cutting mitre joints. The tool is geared and the indicator flag on the top of the tool indicates exactly where the blade needs to be in order to cut a perfect mitre, the machine does this by automatically halving the
  • 01:58 Popular Two spanner trick | wrench extender
    by Admin Added 2,069 Views / 0 Likes
    Using two spanners doubled up is not a good idea, a dedicated wrench extender is a much safer option.
  • 04:17 Popular Ultimate Tool storage | tool cabinet
    by Admin Added 1,712 Views / 1 Likes
    Storing tools can be difficult especially if you have a large amount. I realised that I was wasting hours each week simply looking for the correct tools. Now the tools are stored correctly I know exactly where they are, all of the time.
  • 01:36 Popular Using a chalk line
    Using a chalk line
    by Admin Added 1,831 Views / 0 Likes
    Chalk Lines can be purchased for less than £5 and can make marking out much easier, just hook the chalk line over a screw head, pull the line tight and then snap the chalk line down. This will leave a straight chalk line for you to follow.
