Tool videos
Tools are as necessary to a man as handbags are to women, you simply cannot have enough tools!
This section shows how to use some basic tools and also describes what some more obscure and less well known tools are used for.
  • 00:56 Popular Hammer drill versus SDS drill
    by Admin Added 2,480 Views / 1 Likes
    Apart from the chuck an SDS machine is far more powerful for drilling masonry due to the built in pneumatic hammer as this video demonstrates
  • 01:58 Popular Angle grinder to shape wood
    by Admin Added 2,409 Views / 0 Likes
    Wood can easily and quickly be shaped with an angle grinder using a flexible sanding pad and abrasive disc. In this video I scallop a piece of wood using this technique. This is also a fast and efficient way of removing excess timber, or rounding off shar
  • 03:42 Popular Trend Angle fix | Angle finder
    by Admin Added 2,309 Views / 0 Likes
    The trend angle fix is very useful for cutting mitre joints. The tool is geared and the indicator flag on the top of the tool indicates exactly where the blade needs to be in order to cut a perfect mitre, the machine does this by automatically halving the
  • 02:31 Popular How to use hinge drills
    by Admin Added 2,235 Views / 0 Likes
    Hinge drills or hinge siting drills are a very useful drill for ensuring that the screw pilot hole is drilled in the dead centre of the hinge fixing hole. Please ensure that you do not buy a cheap set of these as they will not work as well as a decent qua
  • 01:58 Popular Two spanner trick | wrench extender
    by Admin Added 2,202 Views / 0 Likes
    Using two spanners doubled up is not a good idea, a dedicated wrench extender is a much safer option.
  • 02:47 Popular Never buy cheap tools
    by Admin Added 2,191 Views / 2 Likes
    Cheap tools are often false economy and can make your job ten times harder. Buy cheap buy twice is a motto that is very true
    by Admin Added 2,088 Views / 0 Likes
  • 06:38 Popular How to use a biscuit joiner
    by Admin Added 2,017 Views / 2 Likes
    A biscuit joiner, sometimes called a biscuit jointer or plate jointer is useful when making widening joints.
  • 05:25 Popular Choosing a cordless drill
    by Admin Added 1,947 Views / 0 Likes
    practical advice when considering buying a new cordless drill. For some people this can be a confusing issue and so hopefully this video will help to explain a few things.
  • 01:36 Popular Using a chalk line
    Using a chalk line
    by Admin Added 1,904 Views / 0 Likes
    Chalk Lines can be purchased for less than £5 and can make marking out much easier, just hook the chalk line over a screw head, pull the line tight and then snap the chalk line down. This will leave a straight chalk line for you to follow.
  • 04:17 Popular Ultimate Tool storage | tool cabinet
    by Admin Added 1,784 Views / 1 Likes
    Storing tools can be difficult especially if you have a large amount. I realised that I was wasting hours each week simply looking for the correct tools. Now the tools are stored correctly I know exactly where they are, all of the time.
  • 10:43 Popular How to use a circular saw safely
    by Admin Added 1,762 Views / 2 Likes
    Circular saws can be extremely useful if used correctly but each year thousands of people are injured by these saws. Many of the accidents can be avoided by using the saws correctly, this video addresses some of the issues and will hopefully make people m
  • 08:32 Popular How to use a cordless drill driver
    by Admin Added 1,688 Views / 1 Likes
    Cordless drill drivers are now extremely common but unfortunately many people cannot use them to their full potential. In this video I show how to use all of the features of the Dewalt 18v cordless combination drill, including torque control which is very
  • 03:43 Popular Drilling hardened steel with ARTU drill bits
    by Admin Added 1,645 Views / 1 Likes
    Drilling through hardened steel is now possible using ARTU multipurpose drill bits.
  • 02:33 Popular Pipe squeeze off tool
    by Admin Added 1,577 Views / 0 Likes
    Pipe squeeze off tools are used by water and utility companies to squeeze the incoming water supply pipe closed when changing the main stop cock to the property. Smaller versions are also available for squeezing the flexible brake pipes on vehicles when r
  • 01:53 Popular How to use a bell punch
    by Admin Added 1,542 Views / 0 Likes
    A bell punch is designed for centre punching the exact centre of a round bar. This inexpensive tool is very useful and is often called a bell centre punch. Marking the exact centre of a round bar has never been so easy !
