Tool videos
Tools are as necessary to a man as handbags are to women, you simply cannot have enough tools!
This section shows how to use some basic tools and also describes what some more obscure and less well known tools are used for.
  • 01:58 Popular Angle grinder to shape wood
    by Admin Added 2,479 Views / 0 Likes
    Wood can easily and quickly be shaped with an angle grinder using a flexible sanding pad and abrasive disc. In this video I scallop a piece of wood using this technique. This is also a fast and efficient way of removing excess timber, or rounding off shar
  • 05:25 Popular Choosing a cordless drill
    by Admin Added 1,999 Views / 0 Likes
    practical advice when considering buying a new cordless drill. For some people this can be a confusing issue and so hopefully this video will help to explain a few things.
  • 04:12 Popular Cutting steel channel with the Rage 3S
    by Admin Added 771 Views / 0 Likes
    The Evolution Rage 3s 210mm has a maximum metal cutting capacity of 6mm, but in this demonstration I cut through a piece of steel channel that measures 200mm by 100mm and is roughly 10mm thick in places. It’s not recommended to cut such large pieces
  • 03:43 Popular Drilling hardened steel with ARTU drill bits
    by Admin Added 1,710 Views / 1 Likes
    Drilling through hardened steel is now possible using ARTU multipurpose drill bits.
  • 01:08 Popular DURA-INK 5 fine Tip marker
    by Admin Added 1,249 Views / 1 Likes
    The Dura-ink Extended tip marker is very useful for marking through holes that a normal marker will not fit through.
  • 04:57 Popular Grinder safety
    Grinder safety
    by Admin Added 1,575 Views / 0 Likes
    Some important safety considerations before using an angle grinder or cut off saw
  • 00:56 Popular Hammer drill versus SDS drill
    by Admin Added 2,659 Views / 1 Likes
    Apart from the chuck an SDS machine is far more powerful for drilling masonry due to the built in pneumatic hammer as this video demonstrates
  • 07:29 Popular How to fit angle grinder disc
    by Admin Added 1,574 Views / 1 Likes
    Installing a disc on to an angle grinder is not as simple as it first seems. Many Angle grinders are purchased with poor instructions. This video shows how to mount a cutting disc or grinding disc to an angle grinder. Many people are not aware that abrasi
  • 01:53 Popular How to use a bell punch
    by Admin Added 1,603 Views / 0 Likes
    A bell punch is designed for centre punching the exact centre of a round bar. This inexpensive tool is very useful and is often called a bell centre punch. Marking the exact centre of a round bar has never been so easy !
  • 06:38 Popular How to use a biscuit joiner
    by Admin Added 2,091 Views / 2 Likes
    A biscuit joiner, sometimes called a biscuit jointer or plate jointer is useful when making widening joints.
  • 10:43 Popular How to use a circular saw safely
    by Admin Added 1,850 Views / 2 Likes
    Circular saws can be extremely useful if used correctly but each year thousands of people are injured by these saws. Many of the accidents can be avoided by using the saws correctly, this video addresses some of the issues and will hopefully make people m
  • 08:32 Popular How to use a cordless drill driver
    by Admin Added 1,772 Views / 2 Likes
    Cordless drill drivers are now extremely common but unfortunately many people cannot use them to their full potential. In this video I show how to use all of the features of the Dewalt 18v cordless combination drill, including torque control which is very
  • 07:57 Popular How to use a hacksaw
    by Admin Added 1,120 Views / 1 Likes
    A hacksaw is a very handy tool when working with metal or plastics and is a cheap way to cut these materials. This video shows how to fit the blade and cut metal using a hacksaw.
  • 07:38 Popular How to use a mag base drill
    by Admin Added 944 Views / 0 Likes
    This video shows how to use a mag base drill, or magnetic base drill. Magnetic base drills are widely used in all industrial and construction environments and are one of the most useful drills that you can possibly imagine. Sometimes there is no steel for
  • 14:40 Popular How to use a mitre saw safely
    by Admin Added 1,123 Views / 0 Likes
    Mitre saws are now very common and can be picked up very inexpensively. It is however very important that these machines are used safely to avoid potential injuries to the mitre saw use. This video looks at using the sliding mitre saw in a safe manner and
    by Admin Added 2,165 Views / 0 Likes
