DIY videos from Ultimate Handyman
  • 05:39 Popular How to replace the hose pipe in a Hozelock reel
    by Admin Added 1,271 Views / 0 Likes
    This video shows how to replace a damaged hose pipe in a Hozelock auto reel. The hose pipe in this reel had split in several places and required replacing. The hose length is about 30 metres or £150 feet. This was a bit of a challenge as some of the
  • 04:40 Popular How to repoint a lead roof valley
    by Admin Added 1,059 Views / 0 Likes
    This video shows how to re-point the lead valley on a tiled roof safely using fibre reinforced mortar.
  • 03:19 Popular How to repair a crack in a wall
    by Admin Added 1,477 Views / 0 Likes
    Cracks can often appear in plastered or drywall walls due to settlement or slight movement. In most cases the cracks are nothing to worry about and are only cosmetic. These cracks in the plaster or cracks in the drywall can easily be fixed using a suitabl
  • 03:21 Popular How to remove moss from a roof
    by Admin Added 1,862 Views / 0 Likes
    Removing moss from a roof can seem like a difficult task, some people reach for the pressure washer but often you can clean the roof simply using a stiff brush. Once the moss is removed from the roof the tiles are then brushed again before the roof is spr
