    by Admin Added 2,446 Views / 1 Likes
  • 00:57 Popular Removing a wall plug
    by Admin Added 2,117 Views / 2 Likes
    This video shows how to easily remove a wall plug that is no longer required and also how to fill the hole in an external wall to prevent frost damage
  • 03:35 Popular Removing plaster with a SDS drill
    by Admin Added 2,462 Views / 0 Likes
    Removing plaster from walls can be done using a bolster chisel and hammer, but it is much easier with a SDS drill that has a roto stop function and a suitable chisel.
  • 01:40 Popular Removing staples with the Tacwise pro staple remover
    by Admin Added 988 Views / 0 Likes
  • 03:00 Popular Removing sticky labels
    by Admin Added 1,815 Views / 1 Likes
    The adhesive used by label manufacturers can be extremely difficult to remove.
  • 03:30 Popular Ride on mower wheel replacement
    by Admin Added 989 Views / 0 Likes
    Here the back wheel on this Efco lawn mower is removed for puncture repair and then replaced, the wheel is held on using an E clip and washer. It's a good idea to clean the shaft and apply some copper grease before replacing the wheel as this will make it
  • 02:29 Popular Roofing felt repair
    Roofing felt repair
    by Admin Added 1,633 Views / 0 Likes
    If you discover a hole in your roofing felt it can quite easily be repaired from inside using some flashbanding
  • 05:33 Popular Safety gloves | Work gloves
    by Admin Added 755 Views / 1 Likes
    Safety gloves are very important when working or carrying out DIY. Each year thousands of people end up in hospital due to injuries that could have been prevented by wearing the correct safety gloves or work gloves. Some of the sites I work on make it man
    by Admin Added 2,764 Views / 1 Likes
  • 16:41 Popular Sinking an electrical backbox
    by Admin Added 4,455 Views / 0 Likes
    How to fit an electrical double back box onto a solid brick wall that has been wallpapered. Fitting a back box is normally done before the wall is papered but if you wanted to add an extra socket in your home and the wall has been papered then this video
  • 05:40 Popular Spirit level tutorial
    by Admin Added 1,434 Views / 0 Likes
    A spirit level is very useful when doing a wide variety of DIY projects from wallpapering to installing decking. This video shows how to use a spirit level in normal use and also how to use a level to calculate a fall when installing decking.
  • 05:28 Popular Surface drain unblocking
    by Admin Added 1,625 Views / 0 Likes
    Surface drains can easily become blocked with debris, therefore it is a good idea to clear them before they get blocked and cause problems. Often this is simply a case of lifting off the covers and removing the debris.
  • 01:01 Popular Tips when drilling into a wall
    by Admin Added 2,529 Views / 0 Likes
    Here are a few tips for drilling into a wall
  • 02:09 Popular Top DIY hacks
    Top DIY hacks
    by Admin Added 13k Views / 1 Likes
    Little DIY jobs around the house can add up to be quite expensive. But with my quick DIY hacks I’ll teach you how to save a fortune. These simple fixes to traditional jobs will also save you a lot of time.
  • 14:07 Popular Transcend Drivepro 100 dashcam review
    by Admin Added 667 Views / 0 Likes
    In this video the Transcend Drivepro 100 dashcam is reviewed by Mike.
  • 01:36 Popular Using a chalk line
    Using a chalk line
    by Admin Added 1,879 Views / 0 Likes
    Chalk Lines can be purchased for less than £5 and can make marking out much easier, just hook the chalk line over a screw head, pull the line tight and then snap the chalk line down. This will leave a straight chalk line for you to follow.
