    by Admin Added 1,805 Views / 0 Likes
  • 03:49 Popular How to cut a bolt without damaging the threads
    by Admin Added 4,306 Views / 0 Likes
    This video shows how to cut a bolt using a hacksaw or a pair of electrical crimping pliers. Cutting a bolt has never been so easy!
  • 05:00 Popular How to cut plasterboard
    by Admin Added 1,452 Views / 0 Likes
    How to cut plasterboard/drywall, using the score and snap technique
  • 05:39 Popular Lifting floor boards
    by Admin Added 1,818 Views / 0 Likes
    Lifting floor boards is often required when doing DIY, here we demonstrate an easy way to lift floor boards so that they can be replaced with the minimum of making good afterwards.
  • 03:42 Popular How to install deck posts | Decking posts
    by Admin Added 1,686 Views / 0 Likes
    Decking posts are often installed when building an elevated deck, this video shows how to install the posts and ensure that the posts last as long as possible. Please be aware that some decks require planning permission and some decks require designing by
  • 03:30 Popular Ride on mower wheel replacement
    by Admin Added 990 Views / 0 Likes
    Here the back wheel on this Efco lawn mower is removed for puncture repair and then replaced, the wheel is held on using an E clip and washer. It's a good idea to clean the shaft and apply some copper grease before replacing the wheel as this will make it
  • 02:14 Popular Broken double glazed window on the inside
    by Admin Added 733 Views / 0 Likes
    This video briefly shows what can happen to double glazed windows in cold weather once the sun heats the unit up too quickly. The difference in temperature can cause the window to implode, as you can see from the pane of glass on the inside of this double
  • 03:46 Popular how to fit a back box in plasterboard
    by Admin Added 1,683 Views / 0 Likes
    How to fit a dry lining back box in a plasterboard wall.
  • 08:55 Popular wallpaper stripping using Zinsser DIF and paper tiger
    by Admin Added 1,677 Views / 0 Likes
    Here I strip wallpaper using Zinsser DIF and Zinsser's paper tiger, this is the best way I have found to remove wallpaper easily and quickly with the least amount of work.
  • 02:26 Popular How to use Flashband
    by Admin Added 3,497 Views / 0 Likes
    Flashband can be used for repairs to leaking roofs and most sound surfaces, some absorbent surfaces may require priming before applying the flashband tape, this will help the tape to stick. Applying heat to the flash band will also help it to stick.
  • 02:29 Popular Roofing felt repair
    Roofing felt repair
    by Admin Added 1,633 Views / 0 Likes
    If you discover a hole in your roofing felt it can quite easily be repaired from inside using some flashbanding
  • 03:06 Popular Drilling through cavity walls
    by Admin Added 2,466 Views / 0 Likes
    This video demonstrates how to drill through a cavity wall
  • 02:57 Popular Remove rust stains from stone or masonry
    by Admin Added 1,354 Views / 0 Likes
    This video shows how to remove rust stains from stone. You can use oxalic acid or Nettrol to remove the rust stain.
  • 02:09 Popular Top DIY hacks
    Top DIY hacks
    by Admin Added 13k Views / 1 Likes
    Little DIY jobs around the house can add up to be quite expensive. But with my quick DIY hacks I’ll teach you how to save a fortune. These simple fixes to traditional jobs will also save you a lot of time.
  • 05:39 Popular How to replace the hose pipe in a Hozelock reel
    by Admin Added 984 Views / 0 Likes
    This video shows how to replace a damaged hose pipe in a Hozelock auto reel. The hose pipe in this reel had split in several places and required replacing. The hose length is about 30 metres or £150 feet. This was a bit of a challenge as some of the
  • 04:40 Popular How to repoint a lead roof valley
    by Admin Added 861 Views / 0 Likes
    This video shows how to re-point the lead valley on a tiled roof safely using fibre reinforced mortar.
