  • 02:29 Popular Roofing felt repair
    Roofing felt repair
    by Admin Added 1,752 Views / 0 Likes
    If you discover a hole in your roofing felt it can quite easily be repaired from inside using some flashbanding
  • 03:06 Popular Drilling through cavity walls
    by Admin Added 2,766 Views / 0 Likes
    This video demonstrates how to drill through a cavity wall
  • 02:57 Popular Remove rust stains from stone or masonry
    by Admin Added 1,462 Views / 0 Likes
    This video shows how to remove rust stains from stone. You can use oxalic acid or Nettrol to remove the rust stain.
  • 02:09 Popular Top DIY hacks
    Top DIY hacks
    by Admin Added 13.4k Views / 1 Likes
    Little DIY jobs around the house can add up to be quite expensive. But with my quick DIY hacks I’ll teach you how to save a fortune. These simple fixes to traditional jobs will also save you a lot of time.
  • 08:32 Popular How to remove small stripped screws | stripped laptop screws | stripped phone screw removal
    by Admin Added 220 Views / 0 Likes
    Removing small stripped screws can be difficult, in this video I remove some small rounded or stripped screws from a couple of small items including a mobile phone. There are a lot of different types of screw head/drivers available and so it’s best
  • 07:15 Popular How to use a diamond core drill
    by Admin Added 3,203 Views / 0 Likes
    How to use a diamond core drill to drill a large diameter hole through a solid wall.
  • 06:46 Popular How to clean out a cavity wall
    by Admin Added 1,923 Views / 0 Likes
    It may be necessary to clean debris from your cavity, especially before you install a damp proof course. Debris in the cavity can cause damp to pass from the outside skin of the property to the inside and it can also cause a cold bridge which attracts con
  • 03:21 Popular Drilling glass | spear point glass drill
    by Admin Added 1,737 Views / 0 Likes
    Glass can easily be drilled using a spear point glass drill bit, these bits will also drill ceramic tiles! For larger holes you can use a diamond coated holesaw. Whichever drill bit you use to drill the glass you will need some coolant/lubricant, Parrafin
  • 01:40 Popular Removing staples with the Tacwise pro staple remover
    by Admin Added 1,169 Views / 0 Likes
  • 09:03 Popular How to replace a double glazed unit
    by Admin Added 790 Views / 0 Likes
    This video shows how to replace a double glazed unit in a double glazed UPVC window frame. This window has imploded so the glass is quite badly broken, How this happened is described in this video- https://www.youtube.com/watch?v=I3fGXFRZ3zQ You might be
  • 05:40 Popular Spirit level tutorial
    by Admin Added 1,522 Views / 0 Likes
    A spirit level is very useful when doing a wide variety of DIY projects from wallpapering to installing decking. This video shows how to use a spirit level in normal use and also how to use a level to calculate a fall when installing decking.
  • 01:36 Popular Using a chalk line
    Using a chalk line
    by Admin Added 1,993 Views / 0 Likes
    Chalk Lines can be purchased for less than £5 and can make marking out much easier, just hook the chalk line over a screw head, pull the line tight and then snap the chalk line down. This will leave a straight chalk line for you to follow.
  • 03:20 Popular How to remove Moss
    How to remove Moss
    by Admin Added 1,817 Views / 0 Likes
    How to quickly remove Moss
  • 16:41 Popular Sinking an electrical backbox
    by Admin Added 4,676 Views / 0 Likes
    How to fit an electrical double back box onto a solid brick wall that has been wallpapered. Fitting a back box is normally done before the wall is papered but if you wanted to add an extra socket in your home and the wall has been papered then this video
  • 06:11 How to break up concrete
    by Admin Added 38 Views / 0 Likes
    how to break up concrete using the Hilti Te2000 AVR, breaker. In this video we break up a concrete slab using a Hilti breaker, which was hired from HSS. It can be difficult breaking up concrete, but this breaker made very light work of it. The concrete ba
  • 03:57 Popular How to fix a leaking gutter
    by Admin Added 2,713 Views / 0 Likes
    Gutters can eventually leak, perhaps because the joint has separated slightly, in this video we clean the gutter out and then apply plumbers gold which is a sealant that can be used in wet conditions. This seals the joint in the gutter and stops the leak.
