  • 05:15 Popular How to fix squeaky stairs
    by Admin Added 10.3k Views / 2 Likes
    squeaky stairs can be very annoying, if you can get access to the back of the stairs it is possible to fix the stairs to prevent them from squeaking.
  • 11:24 Popular how to fix squeaky/squeaking/creaking floors/floorboards
    by Admin Added 489 Views / 0 Likes
    how to fix repair squeaky squeaking creaking floors/floorboards. Squeaking floorboards or creaking floorboards are often caused by the boards being loose, the movement that is caused when walking on the boards creates the squeaking or creaking noise. Appa
  • 01:46 Popular How to free rusted parts | Spray penetrant
    by Admin Added 1,471 Views / 0 Likes
    how to free rusted parts using spray penetrant. Often this is all that is required to free rusted parts.
  • 05:55 Popular How to install a garage door floor weather seal
    by Admin Added 2,313 Views / 1 Likes
    One problem with garage doors is that leaves, rain and snow can blow under the gap in the door, by fitting this floor seal you can prevent this from happening in future.
  • 03:42 Popular How to install deck posts | Decking posts
    by Admin Added 1,684 Views / 0 Likes
    Decking posts are often installed when building an elevated deck, this video shows how to install the posts and ensure that the posts last as long as possible. Please be aware that some decks require planning permission and some decks require designing by
  • 10:10 Popular how to kill a wasp nest at height
    by Admin Added 383 Views / 0 Likes
    This video shows how to kill a wasp nest which is at height. Killing a wasp nest at height is particularly dangerous and so I made a pole that could deliver the pesticide into the access hole for the wasp nest from a distance. A couple of attempts were ne
  • 08:18 Popular How to polish brass door furniture
    by Admin Added 1,365 Views / 1 Likes
    How to refurbish brass door furniture, this can save you a lot of money as it is much cheaper than replacement
  • 03:43 Popular How to remove coving
    by Admin Added 1,923 Views / 0 Likes
    Coving is not always in fashion and can spoil the look of a room. Here we show a quick way to remove the coving using a knock through screwdriver and a hammer.
  • 03:20 Popular How to remove Moss
    How to remove Moss
    by Admin Added 1,705 Views / 0 Likes
    How to quickly remove Moss
  • 03:21 Popular How to remove moss from a roof
    by Admin Added 1,634 Views / 0 Likes
    Removing moss from a roof can seem like a difficult task, some people reach for the pressure washer but often you can clean the roof simply using a stiff brush. Once the moss is removed from the roof the tiles are then brushed again before the roof is spr
  • 03:13 Popular How to remove mould
    How to remove mould
    by Admin Added 2,332 Views / 0 Likes
    Removing mould correctly can be difficult. It is essential to use the correct product when removing mould as regular household bleach is ineffective. In this video we use a dedicated mould removal spray to remove mould from a bathroom ceiling.
  • 05:24 Popular How to remove wallpaper
    by Admin Added 1,916 Views / 1 Likes
    How to remove wall paper using a perforated roller and scraper
  • 03:19 Popular How to repair a crack in a wall
    by Admin Added 1,204 Views / 0 Likes
    Cracks can often appear in plastered or drywall walls due to settlement or slight movement. In most cases the cracks are nothing to worry about and are only cosmetic. These cracks in the plaster or cracks in the drywall can easily be fixed using a suitabl
  • 03:14 Popular How to repair Tarmac
    by Admin Added 1,353 Views / 0 Likes
    Damaged patches of Tarmac can easily be repaired inexpensively using a suitable cold lay repair compound.
  • 09:03 Popular How to replace a double glazed unit
    by Admin Added 581 Views / 0 Likes
    This video shows how to replace a double glazed unit in a double glazed UPVC window frame. This window has imploded so the glass is quite badly broken, How this happened is described in this video- https://www.youtube.com/watch?v=I3fGXFRZ3zQ You might be
  • 06:32 Popular How to replace a French door lock
    by Admin Added 2,138 Views / 0 Likes
    French door’s normally rely on two keyed alike euro cylinders to lock them. Replacing one of the cylinders is easy, but the other one is a bit more difficult as you have to remove the keeper plate and often drill a hole through the internal PVC prof
