  • 02:09 Popular Top DIY hacks
    Top DIY hacks
    by Admin Added 13k Views / 1 Likes
    Little DIY jobs around the house can add up to be quite expensive. But with my quick DIY hacks I’ll teach you how to save a fortune. These simple fixes to traditional jobs will also save you a lot of time.
  • 07:15 Popular How to use a diamond core drill
    by Admin Added 2,853 Views / 0 Likes
    How to use a diamond core drill to drill a large diameter hole through a solid wall.
  • 06:46 Popular How to clean out a cavity wall
    by Admin Added 1,814 Views / 0 Likes
    It may be necessary to clean debris from your cavity, especially before you install a damp proof course. Debris in the cavity can cause damp to pass from the outside skin of the property to the inside and it can also cause a cold bridge which attracts con
  • 03:21 Popular Drilling glass | spear point glass drill
    by Admin Added 1,625 Views / 0 Likes
    Glass can easily be drilled using a spear point glass drill bit, these bits will also drill ceramic tiles! For larger holes you can use a diamond coated holesaw. Whichever drill bit you use to drill the glass you will need some coolant/lubricant, Parrafin
  • 01:40 Popular Removing staples with the Tacwise pro staple remover
    by Admin Added 991 Views / 0 Likes
  • 09:03 Popular How to replace a double glazed unit
    by Admin Added 585 Views / 0 Likes
    This video shows how to replace a double glazed unit in a double glazed UPVC window frame. This window has imploded so the glass is quite badly broken, How this happened is described in this video- https://www.youtube.com/watch?v=I3fGXFRZ3zQ You might be
  • 05:40 Popular Spirit level tutorial
    by Admin Added 1,434 Views / 0 Likes
    A spirit level is very useful when doing a wide variety of DIY projects from wallpapering to installing decking. This video shows how to use a spirit level in normal use and also how to use a level to calculate a fall when installing decking.
  • 01:36 Popular Using a chalk line
    Using a chalk line
    by Admin Added 1,880 Views / 0 Likes
    Chalk Lines can be purchased for less than £5 and can make marking out much easier, just hook the chalk line over a screw head, pull the line tight and then snap the chalk line down. This will leave a straight chalk line for you to follow.
  • 03:19 Popular How to repair a crack in a wall
    by Admin Added 1,213 Views / 0 Likes
    Cracks can often appear in plastered or drywall walls due to settlement or slight movement. In most cases the cracks are nothing to worry about and are only cosmetic. These cracks in the plaster or cracks in the drywall can easily be fixed using a suitabl
  • 03:20 Popular How to remove Moss
    How to remove Moss
    by Admin Added 1,705 Views / 0 Likes
    How to quickly remove Moss
  • 16:41 Popular Sinking an electrical backbox
    by Admin Added 4,456 Views / 0 Likes
    How to fit an electrical double back box onto a solid brick wall that has been wallpapered. Fitting a back box is normally done before the wall is papered but if you wanted to add an extra socket in your home and the wall has been papered then this video
  • 03:57 Popular How to fix a leaking gutter
    by Admin Added 2,568 Views / 0 Likes
    Gutters can eventually leak, perhaps because the joint has separated slightly, in this video we clean the gutter out and then apply plumbers gold which is a sealant that can be used in wet conditions. This seals the joint in the gutter and stops the leak.
  • 03:51 Popular Garden burner bins
    Garden burner bins
    by Admin Added 1,622 Views / 0 Likes
    Garden burner bins (incinerator bins) are a great way to burn branches/clean wood in the garden. These incinerators can get to high temperatures and will easily burn most burnable household items although they should only be used for clean wood, paper and
  • 10:10 Popular how to kill a wasp nest at height
    by Admin Added 397 Views / 0 Likes
    This video shows how to kill a wasp nest which is at height. Killing a wasp nest at height is particularly dangerous and so I made a pole that could deliver the pesticide into the access hole for the wasp nest from a distance. A couple of attempts were ne
  • 03:14 Popular How to repair Tarmac
    by Admin Added 1,355 Views / 0 Likes
    Damaged patches of Tarmac can easily be repaired inexpensively using a suitable cold lay repair compound.
  • 01:17 Popular Angle grinder pin wrench trick
    by Admin Added 1,973 Views / 0 Likes
    Undoing the flange nut on an angle grinder can be almost impossible with the incorrect pin wrench, here I demonstrate how to undo the nut with the wrong sized wrench.
