  • 03:35 Popular Removing plaster with a SDS drill
    by Admin Added 2,668 Views / 0 Likes
    Removing plaster from walls can be done using a bolster chisel and hammer, but it is much easier with a SDS drill that has a roto stop function and a suitable chisel.
  • 05:26 Popular How to batten a ceiling
    by Admin Added 2,663 Views / 0 Likes
    Battening a ceiling is often required if the ceiling is to be clad. Tongue and groove cladding can be used or special PVC cladding that is designed for use in bathrooms. The important bit is getting the battens level and secure.
  • 01:27 Popular How to find a wooden stud in a partition wall
    by Admin Added 2,508 Views / 1 Likes
    You do not need to spend money on a gadget to find studs (most of which do not work), just use a magnet
  • 05:55 Popular How to install a garage door floor weather seal
    by Admin Added 2,468 Views / 1 Likes
    One problem with garage doors is that leaves, rain and snow can blow under the gap in the door, by fitting this floor seal you can prevent this from happening in future.
  • 03:13 Popular How to remove mould
    How to remove mould
    by Admin Added 2,457 Views / 0 Likes
    Removing mould correctly can be difficult. It is essential to use the correct product when removing mould as regular household bleach is ineffective. In this video we use a dedicated mould removal spray to remove mould from a bathroom ceiling.
  • 02:42 Popular Clear Silicone Sealant test
    by Admin Added 2,407 Views / 1 Likes
    Sometimes clear silicone sealant is far from clear, here I compare three brands of clear silicone.
  • 06:32 Popular How to replace a French door lock
    by Admin Added 2,300 Views / 0 Likes
    French door’s normally rely on two keyed alike euro cylinders to lock them. Replacing one of the cylinders is easy, but the other one is a bit more difficult as you have to remove the keeper plate and often drill a hole through the internal PVC prof
  • 00:57 Popular Removing a wall plug
    by Admin Added 2,264 Views / 2 Likes
    This video shows how to easily remove a wall plug that is no longer required and also how to fill the hole in an external wall to prevent frost damage
  • 04:41 Popular How to tank a damp concrete floor
    by Admin Added 2,231 Views / 0 Likes
    Here we tank a concrete floor that has no physical damp proof course. Tanking the floor is a great solution that is cheap and will prevent any dampness from rising up through the floor. In this example KA tanking slurry was used which costs about £2
  • 02:20 Popular How to fix a leaking plastic gutter union
    by Admin Added 2,198 Views / 1 Likes
    Plastic gutter unions often leak as the gasket perishes. This video shows how to quickly and easily replace the gasket.
  • 05:24 Popular How to remove wallpaper
    by Admin Added 2,136 Views / 1 Likes
    How to remove wall paper using a perforated roller and scraper
  • 01:46 Popular Drill holes in a ceiling without the dust
    by Admin Added 2,133 Views / 1 Likes
    This video shows how you can use a take away container that would normally be thrown away to catch the dust when drilling holes in a plasterboard ceiling, using a hole saw.
  • 02:53 Popular Gutter cleaning and fitting floguards
    by Admin Added 2,133 Views / 0 Likes
    Gutters can periodically get blocked from leaves etc. This can cause the gutter to overflow which can cause damage to your property. When clearing the cutters it is essential that the correct equipment is used to access the gutter, this will normally invo
  • 01:17 Popular Angle grinder pin wrench trick
    by Admin Added 2,084 Views / 0 Likes
    Undoing the flange nut on an angle grinder can be almost impossible with the incorrect pin wrench, here I demonstrate how to undo the nut with the wrong sized wrench.
  • 02:34 Popular How to cut a socket screw or machine screw
    by Admin Added 2,050 Views / 1 Likes
    How to cut an electrical screw or machine screw using a pair of electricians pliers.
  • 03:43 Popular How to remove coving
    by Admin Added 2,049 Views / 0 Likes
    Coving is not always in fashion and can spoil the look of a room. Here we show a quick way to remove the coving using a knock through screwdriver and a hammer.
