Visit Thermo worx
  • 00:19 Popular halloween prank wheelie bin
    by Admin Added 752 Views / 1 Likes
    What can you make using a wheelie bin and some pneumatic controls? Well you could make a prank wheelie bin to scare your neighbours ;-) Special thanks go out to my neighbours Ian and Carole for being such good sports ;-) How to make this prop will be cove
  • 05:26 Popular How to batten a ceiling
    by Admin Added 2,383 Views / 0 Likes
    Battening a ceiling is often required if the ceiling is to be clad. Tongue and groove cladding can be used or special PVC cladding that is designed for use in bathrooms. The important bit is getting the battens level and secure.
  • 02:06 Popular How to change a euro cylinder
    by Admin Added 1,075 Views / 0 Likes
    Euro cylinders are normally pretty easy to change, this video shows how
  • 06:46 Popular How to clean out a cavity wall
    by Admin Added 1,740 Views / 0 Likes
    It may be necessary to clean debris from your cavity, especially before you install a damp proof course. Debris in the cavity can cause damp to pass from the outside skin of the property to the inside and it can also cause a cold bridge which attracts con
  • 03:49 Popular How to cut a bolt without damaging the threads
    by Admin Added 4,026 Views / 0 Likes
    This video shows how to cut a bolt using a hacksaw or a pair of electrical crimping pliers. Cutting a bolt has never been so easy!
  • 02:34 Popular How to cut a socket screw or machine screw
    by Admin Added 1,815 Views / 1 Likes
    How to cut an electrical screw or machine screw using a pair of electricians pliers.
  • 04:15 Popular how to cut concrete or stone using a chisel
    by Admin Added 2,805 Views / 1 Likes
    Most masonry can be cut using a simple bolster chisel and club hammer, you will of course need a pair of gloves and safety glasses! Straight cuts are very simple using this technique, which is very easy to learn.
  • 05:00 Popular How to cut plasterboard
    by Admin Added 1,383 Views / 0 Likes
    How to cut plasterboard/drywall, using the score and snap technique
  • 00:54 Popular How to cut webbing
    How to cut webbing
    by Admin Added 1,045 Views / 0 Likes
    This video shows how to cut webbing, more importantly it shows how to seal the webbing using a lighter to seal the cut edge to prevent it from fraying.
  • 02:30 Popular How to enlarge a hole saw or core drill hole
    by Admin Added 1,565 Views / 0 Likes
    Once a hole has been cut using a core drill or holesaw it is difficult to enlarge the hole, but here I demonstrate an easy way to acheive this.
  • 01:27 Popular How to find a wooden stud in a partition wall
    by Admin Added 2,108 Views / 1 Likes
    You do not need to spend money on a gadget to find studs (most of which do not work), just use a magnet
  • 03:46 Popular how to fit a back box in plasterboard
    by Admin Added 1,596 Views / 0 Likes
    How to fit a dry lining back box in a plasterboard wall.
    by Admin Added 1,715 Views / 0 Likes
  • 03:57 Popular How to fix a leaking gutter
    by Admin Added 2,491 Views / 0 Likes
    Gutters can eventually leak, perhaps because the joint has separated slightly, in this video we clean the gutter out and then apply plumbers gold which is a sealant that can be used in wet conditions. This seals the joint in the gutter and stops the leak.
  • 02:20 Popular How to fix a leaking plastic gutter union
    by Admin Added 1,966 Views / 1 Likes
    Plastic gutter unions often leak as the gasket perishes. This video shows how to quickly and easily replace the gasket.
  • 07:11 Popular How to fix a loose paving step
    by Admin Added 1,334 Views / 0 Likes
    A loose paving step can be a real danger, here we re-fix a loose paving step using a mortar mix of 5 sand to 1 cement by volume
