Visit Thermo worx
    by Admin Added 2,333 Views / 1 Likes
  • 01:46 Popular How to free rusted parts | Spray penetrant
    by Admin Added 1,391 Views / 0 Likes
    how to free rusted parts using spray penetrant. Often this is all that is required to free rusted parts.
  • 05:28 Popular Surface drain unblocking
    by Admin Added 1,572 Views / 0 Likes
    Surface drains can easily become blocked with debris, therefore it is a good idea to clear them before they get blocked and cause problems. Often this is simply a case of lifting off the covers and removing the debris.
  • 03:02 Popular Energy saving Light bulbs
    by Admin Added 1,444 Views / 0 Likes
    Year on year electricity bills increase at a much higher rate than inflation. By installing low energy light bulbs you can make a substantial saving on your energy bills in a quick time. Typically payback is after 12 months, by that time you have paid for
  • 02:01 Popular How to use bolt cutters | How to use bolt croppers
    by Admin Added 869 Views / 0 Likes
    People often damage the cutting edge of their bolt cutters the first time they use them, this is because most people cut through the shackle of the padlock which immediately dulls the cutter blades as the shackle is made from hardened steel.
  • 14:40 Popular How to use a mitre saw safely
    Mitre saws are now very common and can be picked up very inexpensively. It is however very important that these machines are used safely to avoid potential injuries to the mitre saw use. This video looks at using the sliding mitre saw in a safe manner and
  • 03:35 Popular Removing plaster with a SDS drill
    by Admin Added 2,316 Views / 0 Likes
    Removing plaster from walls can be done using a bolster chisel and hammer, but it is much easier with a SDS drill that has a roto stop function and a suitable chisel.
  • 02:42 Popular Clear Silicone Sealant test
    by Admin Added 2,145 Views / 1 Likes
    Sometimes clear silicone sealant is far from clear, here I compare three brands of clear silicone.
  • 00:19 Popular halloween prank wheelie bin
    by Admin Added 775 Views / 1 Likes
    What can you make using a wheelie bin and some pneumatic controls? Well you could make a prank wheelie bin to scare your neighbours ;-) Special thanks go out to my neighbours Ian and Carole for being such good sports ;-) How to make this prop will be cove
  • 02:06 Popular How to change a euro cylinder
    by Admin Added 1,091 Views / 0 Likes
    Euro cylinders are normally pretty easy to change, this video shows how
  • 02:58 Popular Cutting Polysterene with a hot wire cutter
    by Admin Added 1,607 Views / 0 Likes
    A hot wire cutter is useful for cutting polystyrene.
    by Admin Added 1,732 Views / 0 Likes
  • 03:49 Popular How to cut a bolt without damaging the threads
    by Admin Added 4,073 Views / 0 Likes
    This video shows how to cut a bolt using a hacksaw or a pair of electrical crimping pliers. Cutting a bolt has never been so easy!
  • 05:00 Popular How to cut plasterboard
    by Admin Added 1,395 Views / 0 Likes
    How to cut plasterboard/drywall, using the score and snap technique
  • 05:39 Popular Lifting floor boards
    by Admin Added 1,757 Views / 0 Likes
    Lifting floor boards is often required when doing DIY, here we demonstrate an easy way to lift floor boards so that they can be replaced with the minimum of making good afterwards.
  • 03:42 Popular How to install deck posts | Decking posts
    by Admin Added 1,615 Views / 0 Likes
    Decking posts are often installed when building an elevated deck, this video shows how to install the posts and ensure that the posts last as long as possible. Please be aware that some decks require planning permission and some decks require designing by
