  • 02:09 Popular Top DIY hacks
    Top DIY hacks
    by Admin Added 13.4k Views / 1 Likes
    Little DIY jobs around the house can add up to be quite expensive. But with my quick DIY hacks I’ll teach you how to save a fortune. These simple fixes to traditional jobs will also save you a lot of time.
  • 05:15 Popular How to fix squeaky stairs
    by Admin Added 10.5k Views / 3 Likes
    squeaky stairs can be very annoying, if you can get access to the back of the stairs it is possible to fix the stairs to prevent them from squeaking.
  • 04:35 Popular Mixing cement
    Mixing cement
    by Admin Added 8,845 Views / 0 Likes
    Here we mix mortar to a ratio of 4 sand to 1 cement by volume (never by weight) using a plastic mixing tray and a shovel.
  • 07:13 Popular How to silicone a shower
    by Admin Added 8,727 Views / 0 Likes
    How to use silicone sealant to seal a shower cubicle.
  • 04:15 Popular how to cut concrete or stone using a chisel
    by Admin Added 4,842 Views / 3 Likes
    Most masonry can be cut using a simple bolster chisel and club hammer, you will of course need a pair of gloves and safety glasses! Straight cuts are very simple using this technique, which is very easy to learn.
  • 03:49 Popular How to cut a bolt without damaging the threads
    by Admin Added 4,724 Views / 0 Likes
    This video shows how to cut a bolt using a hacksaw or a pair of electrical crimping pliers. Cutting a bolt has never been so easy!
  • 16:41 Popular Sinking an electrical backbox
    by Admin Added 4,673 Views / 0 Likes
    How to fit an electrical double back box onto a solid brick wall that has been wallpapered. Fitting a back box is normally done before the wall is papered but if you wanted to add an extra socket in your home and the wall has been papered then this video
  • 02:26 Popular How to use Flashband
    by Admin Added 3,692 Views / 1 Likes
    Flashband can be used for repairs to leaking roofs and most sound surfaces, some absorbent surfaces may require priming before applying the flashband tape, this will help the tape to stick. Applying heat to the flash band will also help it to stick.
  • 07:15 Popular How to use a diamond core drill
    by Admin Added 3,198 Views / 0 Likes
    How to use a diamond core drill to drill a large diameter hole through a solid wall.
    by Admin Added 3,063 Views / 1 Likes
  • 06:24 Popular How to use floor levelling compound
    by Admin Added 3,029 Views / 2 Likes
    A solid floor can often be un-level, but before a floor covering is applied (especially tiles) it is often necessary to level the floor. Here we level a very uneven concrete floor using floor levelling compound, which is mixed with cold, clean water. It's
  • 15:27 Popular Bathroom ceiling cladding
    by Admin Added 2,965 Views / 1 Likes
    How to clad a bathroom ceiling using PVC cladding.
  • 03:06 Popular Drilling through cavity walls
    by Admin Added 2,764 Views / 0 Likes
    This video demonstrates how to drill through a cavity wall
  • 03:57 Popular How to fix a leaking gutter
    by Admin Added 2,710 Views / 0 Likes
    Gutters can eventually leak, perhaps because the joint has separated slightly, in this video we clean the gutter out and then apply plumbers gold which is a sealant that can be used in wet conditions. This seals the joint in the gutter and stops the leak.
    by Admin Added 2,681 Views / 1 Likes
  • 01:01 Popular Tips when drilling into a wall
    by Admin Added 2,668 Views / 0 Likes
    Here are a few tips for drilling into a wall
