  • 05:15 Popular How to fix squeaky stairs
    by Admin Added 10.5k Views / 3 Likes
    squeaky stairs can be very annoying, if you can get access to the back of the stairs it is possible to fix the stairs to prevent them from squeaking.
  • 04:15 Popular how to cut concrete or stone using a chisel
    by Admin Added 4,558 Views / 3 Likes
    Most masonry can be cut using a simple bolster chisel and club hammer, you will of course need a pair of gloves and safety glasses! Straight cuts are very simple using this technique, which is very easy to learn.
  • 00:57 Popular Removing a wall plug
    by Admin Added 2,218 Views / 2 Likes
    This video shows how to easily remove a wall plug that is no longer required and also how to fill the hole in an external wall to prevent frost damage
  • 06:24 Popular How to use floor levelling compound
    by Admin Added 2,997 Views / 2 Likes
    A solid floor can often be un-level, but before a floor covering is applied (especially tiles) it is often necessary to level the floor. Here we level a very uneven concrete floor using floor levelling compound, which is mixed with cold, clean water. It's
  • 08:18 Popular How to polish brass door furniture
    by Admin Added 1,443 Views / 1 Likes
    How to refurbish brass door furniture, this can save you a lot of money as it is much cheaper than replacement
  • 02:20 Popular How to fix a leaking plastic gutter union
    by Admin Added 2,156 Views / 1 Likes
    Plastic gutter unions often leak as the gasket perishes. This video shows how to quickly and easily replace the gasket.
  • 02:26 Popular How to use Flashband
    by Admin Added 3,640 Views / 1 Likes
    Flashband can be used for repairs to leaking roofs and most sound surfaces, some absorbent surfaces may require priming before applying the flashband tape, this will help the tape to stick. Applying heat to the flash band will also help it to stick.
  • 05:24 Popular How to remove wallpaper
    by Admin Added 2,065 Views / 1 Likes
    How to remove wall paper using a perforated roller and scraper
  • 15:27 Popular Bathroom ceiling cladding
    by Admin Added 2,895 Views / 1 Likes
    How to clad a bathroom ceiling using PVC cladding.
  • 01:46 Popular Drill holes in a ceiling without the dust
    by Admin Added 2,085 Views / 1 Likes
    This video shows how you can use a take away container that would normally be thrown away to catch the dust when drilling holes in a plasterboard ceiling, using a hole saw.
    by Admin Added 2,957 Views / 1 Likes
  • 02:34 Popular How to cut a socket screw or machine screw
    by Admin Added 1,999 Views / 1 Likes
    How to cut an electrical screw or machine screw using a pair of electricians pliers.
  • 03:00 Popular Removing sticky labels
    by Admin Added 1,884 Views / 1 Likes
    The adhesive used by label manufacturers can be extremely difficult to remove.
  • 03:05 Popular How to use holesaws
    How to use holesaws
    by Admin Added 1,582 Views / 1 Likes
    How to use holesaws to cut out large holes from wood, plastic or metal.
  • 05:55 Popular How to install a garage door floor weather seal
    by Admin Added 2,417 Views / 1 Likes
    One problem with garage doors is that leaves, rain and snow can blow under the gap in the door, by fitting this floor seal you can prevent this from happening in future.
  • 03:46 Popular Gyproc Easi-fill | Gyproc Easi filler
    by Admin Added 1,413 Views / 1 Likes
    Gyproc Easi-fill was originally made for filling the joints between sheets of plasterboard or drywall once they had been fixed to the wall using the direct bond method. I know decorators that have been using it as a filler for years and now Gyproc have re
