Central Heating videos
Central heating can be complicated but the videos in this category are designed to help everyone with their central heating. From adding an expansion vessel to wiring in a wireless thermostat this section will have plenty of videos to help.
  • 03:05 Popular How to solder a wet pipe
    by Admin Added 3,511 Views / 0 Likes
    A common problem when doing plumbing is how to solder a wet pipe, this can be a real problem especially if you cut into a downstairs copper pipe as the rest of the pipes in the house can take hours to drain fully. Obviously the pipe needs to be dry before
  • 02:39 Popular How to tighten radiator valves
    by Admin Added 3,001 Views / 0 Likes
    Radiator valves can be the cause of leaks in some central heating systems, if you find your valves have been leaking it is essential that they are tightened using a suitable spanner and also a pair of water pump pliers in order to support the valve and pr
  • 02:56 Popular How to check an expansion vessel
    by Admin Added 4,775 Views / 0 Likes
    How to test an expansion vessel in a central heating system. If the expansion vessel is suspect it is a good idea to test it using this technique as it will identify a faulty expansion vessel.
