Central Heating videos
Central heating can be complicated but the videos in this category are designed to help everyone with their central heating. From adding an expansion vessel to wiring in a wireless thermostat this section will have plenty of videos to help.
  • 01:28 Popular How to add inhibitor to a central heating system
    by Admin Added 3,740 Views / 1 Likes
    This video shows a quick and easy way to add inhibitor to a central heating system through the towel radiator. It is important that the central heating is switched off and has enough room in the system to accommodate the inhibitor, this can be achieved by
  • 02:09 Popular How to bleed a radiator
    by Admin Added 6,342 Views / 1 Likes
    Radiators may need bleeding if the radiator is warm at the bottom and cold at the top, this is often an easy task, although on a sealed system you may need to re-pressurise the system before all radiators can be successfully bled.
  • 01:57 Popular How to bleed a towel radiator
    by Admin Added 2,473 Views / 0 Likes
    how to bleed a towel radiator, this is often an easy task and is bled the same was a traditional radiator. It is important that the central heating is switched off before bleeding the radiator or else air can be sucked into the system.
  • 02:56 Popular How to check an expansion vessel
    by Admin Added 5,078 Views / 0 Likes
    How to test an expansion vessel in a central heating system. If the expansion vessel is suspect it is a good idea to test it using this technique as it will identify a faulty expansion vessel.
  • 04:12 Popular How to drain down a central heating system
    by Admin Added 7,280 Views / 2 Likes
    Draining down central heating may be necessary if several radiators require removing from the system at the same time. This video shows how to drain down a combi central heating system.
  • 00:58 Popular How to find leaks in a central heating system
    by Admin Added 3,433 Views / 1 Likes
    Central heating leaks can be difficult to find, here we demonstrate an easy way to find a leaking joint.
  • 15:20 Popular How to fit a wireless room thermostat | Honeywell CM921
    by Admin Added 3,947 Views / 1 Likes
    This video shows how to install a wireless room thermostat to a combination boiler. Wireless room thermostats can often save fuel as they keep the room at the exact temperature that you require. The model fitted in this video is the Honeywell CM921 wirele
  • 12:13 Popular How to fit an expansion vessel
    by Admin Added 4,758 Views / 1 Likes
    This video shows how to fit an external expansion vessel to a central heating system. If the built in expansion vessel is faulty in the boiler you need to get a registered gas engineer to replace it, but instead you can fit an external one yourself as you
  • 13:09 Popular How to install a towel radiator
    by Admin Added 3,052 Views / 0 Likes
    installing a towel radiator can be tricky but this guide shows one way of installing a towel radiator. Before fitting the radiator you need to drain down the system.
  • 11:00 Popular How to install Trace heating
    by Admin Added 2,637 Views / 1 Likes
    Trace heating is useful for preventing pipes freezing in winter months. This kit is connected to a thermostat so that the trace heater only switches on when the temperature drops below 5 degrees C. If you constantly get frozen pipes in winter then a trace
  • 02:05 Popular How to isolate a central heating header tank
    by Admin Added 2,652 Views / 0 Likes
    If you need to isolate your central heating header tank this video shows how to do it when there is no isolation valve.
  • 02:41 Popular How to recharge an expansion vessel in a combi boiler
    by Admin Added 8,699 Views / 2 Likes
    If your central heating system is loosing pressure on a regular basis the expansion vessel may need recharging, or the vessel may of failed and need replacing (please watch the video on how to test an expansion vessel). The expansion vessel can be recharg
  • 07:32 Popular How to remove a radiator from a central heating system
    by Admin Added 4,286 Views / 1 Likes
    How to remove a radiator from a central heating system, this is often useful if you want to decorate behind the radiator or wish to replace the radiator.
  • 11:01 Popular How to replace a boiler time clock | Ferroli Falcon
    by Admin Added 2,761 Views / 2 Likes
    Some boilers have built in integral time clocks, if the clock fails the boiler may not operate correctly. This video shows how to change a boiler time clock as it is a simple like for like replacement.
  • 03:05 Popular How to solder a wet pipe
    by Admin Added 3,862 Views / 0 Likes
    A common problem when doing plumbing is how to solder a wet pipe, this can be a real problem especially if you cut into a downstairs copper pipe as the rest of the pipes in the house can take hours to drain fully. Obviously the pipe needs to be dry before
  • 02:05 Popular How to thaw Frozen pipes
    by Admin Added 2,426 Views / 1 Likes
    Frozen pipes need thawing out carefully, here we show one of the easiest options on a condensing boiler's condensate pipe
