Central Heating videos
Central heating can be complicated but the videos in this category are designed to help everyone with their central heating. From adding an expansion vessel to wiring in a wireless thermostat this section will have plenty of videos to help.
  • 02:56 Popular How to top up or repressurise a combi boiler
    by Admin Added 21.8k Views / 5 Likes
    Many sealed boilers such as combination boilers will not operate if the pressure in the central heating side of the system drops below a certain pressure (often 1 bar). This video shows how to re-pressurise your system so that you can get the boiler worki
  • 02:41 Popular How to recharge an expansion vessel in a combi boiler
    by Admin Added 8,610 Views / 2 Likes
    If your central heating system is loosing pressure on a regular basis the expansion vessel may need recharging, or the vessel may of failed and need replacing (please watch the video on how to test an expansion vessel). The expansion vessel can be recharg
  • 11:01 Popular How to replace a boiler time clock | Ferroli Falcon
    by Admin Added 2,742 Views / 2 Likes
    Some boilers have built in integral time clocks, if the clock fails the boiler may not operate correctly. This video shows how to change a boiler time clock as it is a simple like for like replacement.
  • 04:12 Popular How to drain down a central heating system
    by Admin Added 7,219 Views / 2 Likes
    Draining down central heating may be necessary if several radiators require removing from the system at the same time. This video shows how to drain down a combi central heating system.
  • 07:32 Popular How to remove a radiator from a central heating system
    by Admin Added 4,253 Views / 1 Likes
    How to remove a radiator from a central heating system, this is often useful if you want to decorate behind the radiator or wish to replace the radiator.
  • 01:28 Popular How to add inhibitor to a central heating system
    by Admin Added 3,721 Views / 1 Likes
    This video shows a quick and easy way to add inhibitor to a central heating system through the towel radiator. It is important that the central heating is switched off and has enough room in the system to accommodate the inhibitor, this can be achieved by
  • 11:00 Popular How to install Trace heating
    by Admin Added 2,615 Views / 1 Likes
    Trace heating is useful for preventing pipes freezing in winter months. This kit is connected to a thermostat so that the trace heater only switches on when the temperature drops below 5 degrees C. If you constantly get frozen pipes in winter then a trace
  • 02:05 Popular How to thaw Frozen pipes
    by Admin Added 2,396 Views / 1 Likes
    Frozen pipes need thawing out carefully, here we show one of the easiest options on a condensing boiler's condensate pipe
  • 02:09 Popular How to bleed a radiator
    by Admin Added 6,290 Views / 1 Likes
    Radiators may need bleeding if the radiator is warm at the bottom and cold at the top, this is often an easy task, although on a sealed system you may need to re-pressurise the system before all radiators can be successfully bled.
  • 12:13 Popular How to fit an expansion vessel
    by Admin Added 4,720 Views / 1 Likes
    This video shows how to fit an external expansion vessel to a central heating system. If the built in expansion vessel is faulty in the boiler you need to get a registered gas engineer to replace it, but instead you can fit an external one yourself as you
  • 15:20 Popular How to fit a wireless room thermostat | Honeywell CM921
    by Admin Added 3,921 Views / 1 Likes
    This video shows how to install a wireless room thermostat to a combination boiler. Wireless room thermostats can often save fuel as they keep the room at the exact temperature that you require. The model fitted in this video is the Honeywell CM921 wirele
  • 00:58 Popular How to find leaks in a central heating system
    by Admin Added 3,411 Views / 1 Likes
    Central heating leaks can be difficult to find, here we demonstrate an easy way to find a leaking joint.
  • 01:57 Popular How to bleed a towel radiator
    by Admin Added 2,464 Views / 0 Likes
    how to bleed a towel radiator, this is often an easy task and is bled the same was a traditional radiator. It is important that the central heating is switched off before bleeding the radiator or else air can be sucked into the system.
  • 02:56 Popular Joining chrome pipe
    Joining chrome pipe
    by Admin Added 2,089 Views / 0 Likes
    Chrome pipe can be difficult to join, this video explains why
  • 03:05 Popular How to solder a wet pipe
    by Admin Added 3,815 Views / 0 Likes
    A common problem when doing plumbing is how to solder a wet pipe, this can be a real problem especially if you cut into a downstairs copper pipe as the rest of the pipes in the house can take hours to drain fully. Obviously the pipe needs to be dry before
  • 02:39 Popular How to tighten radiator valves
    by Admin Added 3,202 Views / 0 Likes
    Radiator valves can be the cause of leaks in some central heating systems, if you find your valves have been leaking it is essential that they are tightened using a suitable spanner and also a pair of water pump pliers in order to support the valve and pr
