Burglar Alarm videos
Burglar alarms are now very common in most homes.
This section has videos showing how to install a burglar alarm including how to wire up the sensors and PA button. You can also see how to replace the battery in a burglar alarm
  • 09:07 Popular burglar alarm remote keypad Installation | Accenta +
    by Admin Added 1,856 Views / 1 Likes
    This video shows how to wire two Accenta + Remote keypads to a Honeywell ADE Gen 4 alarm panel. One RKP is installed in a nearby office and the other RKP is installed in the Garage. Up to 4 RKP's can be installed to control the Honeywell ADE Gen 4 alarm.
  • 04:22 Popular Burglar alarm goes off when power comes back on
    by Admin Added 191 Views / 0 Likes
    Burglar alarm goes off when power comes back on is a very common problem with many house alarms and in most cases it means that the alarm’s internal battery is flat or no longer working. Rectifying a house alarm sound when power cut is very easy and
  • 05:53 Popular How to install an external sounder | Alarm wiring
    by Admin Added 2,091 Views / 0 Likes
    This video shows how to install and wire an AZ-Tech external sounder unit to a Honeywell ADE Gen 4 Burglar alarm panel.
  • 01:54 Popular How to strip Burglar alarm cable
    by Admin Added 1,721 Views / 0 Likes
    This video shows how to easily strip Burglar Alarm cable by using the in-built string.
  • 03:53 Popular How to install the Master Blaster siren
    by Admin Added 1,498 Views / 0 Likes
    This video shows how to fix and wire the Master blaster sounder to an ADE Gen 4 burglar alarm.
  • 05:57 Popular Reed switch Installation | Magnetic door contact
    by Admin Added 1,788 Views / 0 Likes
    Reed switches are often installed on alarm systems and are more commonly known as Magnetic door contacts, here we explain how they work and also show how to wire one to an alarm panel
  • 11:39 Popular How to install a Fused connection unit | FCU
    by Admin Added 3,458 Views / 0 Likes
    This video shows a DIY'er how to install a fused connection unit, often called a FCU. Useful links-http://www.ultimatehandyman.co.uk/routing_a_cable.htm#The latest requirements for running cables is below-http://www.ultimatehandyman.co.uk/forum1/diy-elect
  • 08:25 Popular How to wire a Burglar Alarm PIR detector
    by Admin Added 2,202 Views / 0 Likes
    Here I wire a Texacom PIR to an ADE Gen 4 Burglar alarm. PIR’s are an extremely popular way of triggering a Burglar Alarm and can be found in most domestic and industrial Alarm Systems.
  • 07:04 Popular How to install a burglar alarm | ADE Gen 4 | Accenta
    by Admin Added 3,163 Views / 0 Likes
    This video shows how to install and commission the Honeywell ADE Gen 4 burglar alarm. There are several videos that you will need to complete the job from start to finish, they are-http://www.youtube.com/watch?v=0lsno4HTdrchttp://www.youtube.com/watch?v=4
  • 09:02 Popular How to wire a Personal Attack button to a Burglar alarm
    by Admin Added 1,231 Views / 0 Likes
    Wiring a personal attack button into a burglar alarm is relatively easy as long as you remember to wire the tamper circuit in series. Also if wiring in more than one PA button these also require wiring in series.
  • 01:14 Popular Master Blaster demonstration | 127db alarm Siren
    by Admin Added 1,844 Views / 0 Likes
    As well as having a fully working alarm you can also add additional devices to make it more effective. Here we test out the 127db master blaster.
