Appliance Repair videos
In the appliance repair section we have videos showing how to do basic appliance repair such as replacing the brushes in a washing machine motor.
Most home appliances such as washing machines are normally very reliable and should last for years but occasionally they do go wrong. The videos in this section should help when it comes to fixing your own washing machine.
  • 05:08 Popular How to replace the brushes in a washing machine motor
    by Admin Added 3,832 Views / 0 Likes
    If the brushes in your washing machine motor wear down too far the machine will not work, replacing the brushes if often easy and can cost as little as £10 for a new set of brushes.
  • 03:31 Popular How to replace a water inlet valve on a washing machine or dishwasher
    by Admin Added 2,599 Views / 0 Likes
    How to replace a water inlet valve on a washing machine. If the water inlet valve fails the machine will not fill with water. If the machine fills with water when the machine is switched off the water inlet valve may be passing. Some machines have one wat
  • 03:24 Popular How to fit a washing machine belt
    by Admin Added 2,408 Views / 0 Likes
    A washing machine belt is normally easy to fit on most machines, although some machines are more difficult than others. On a machine with the motor on the top of the drum it is normally easy to fit a new belt on the machine if the old belt becomes stretch
  • 04:02 Popular How to check a faulty washing machine pump
    by Admin Added 2,400 Views / 0 Likes
    How to check a washing machine pump for a blockage and how to test it for an open circuit using a multi-meter.
  • 02:51 Popular How to remove a washing machine pump
    by Admin Added 2,178 Views / 0 Likes
    If the washing machine pump is suspect it it sometimes useful to remove it from the machine to unblock and test, this video shows how to remove a washing machine pump.
  • 03:13 Popular How to fit a washing machine motor
    by Admin Added 1,975 Views / 0 Likes
    Fitting a washing machine motor should be easy as you will probably of removed the motor in the first place. This video shows how to fit a motor to a Hotpoint washing machine.
  • 05:43 Popular How to remove a washing machine motor
    by Admin Added 1,837 Views / 0 Likes
    Removing a washing machine motor is often necessary if it is suspected that the motor brushes need replacing, this video shows how to remove the motor from a Hotpoint washing machine.
  • 02:01 Popular How to fit a washing machine pump
    by Admin Added 1,753 Views / 0 Likes
    A washing machine can often be fixed whilst on the machine by splitting the pump on the machine and leaving the pump housing connected to the machine, but it is often just as easy to remove the pump fully from the machine in order to clear a blockage or c
  • 08:24 Popular How to replace the printed circuit board in a Hoover or Candy washing machine
    by Admin Added 1,512 Views / 0 Likes
    In this video the printed circuit board is replaced with a new one. The old circuit board had a faulty selector switch on it, which meant that some programs no longer worked. Replacing the circuit board is not difficult and can be done in about half an ho
