It is currently Sat May 26, 2012 12:20 am
PostPosted: Sun Jul 25, 2010 9:52 pm
Has thanked: 1 times
Hi
Changing the bathroom light which had 2 black, 2 joined red and earth.
New light fitting has 4 connectors, brown, blue and earth plus one spare if it is te end of the circuit.
Fitted red to brown; earth's and one of the black to blue, other one spare. First time fused, so swapped over the blacks, did not fuse, but no light. Why? and how do I remdy?
Any help gratefully received
Cheers
PostPosted: Sun Jul 25, 2010 11:03 pm
Has thanked: 4 times
Been thanked: 35 times
You have wired it incorrectly... but before we get to that... the way you have wired it your light should be permanantly on! :scratch:
Did you change the fuse when it blew?
Did you check the light bulb?
PostPosted: Sun Jul 25, 2010 11:37 pm
When you have checked the fuse is wired correctly & the bulb has not blown...
FIRST LABEL THE LOOSE BLACK WIRE YOU HAVE... then rewire...
TERMINAL 1 = ALL EARTHS
TERMINAL 2 = 2 REDS
TERMINAL 3 = BLACK + BLUE
TERMINAL 4 = BLACK (LABEL) + BROWN
:thumbright:
For this message the author bright_spark has received gratitude : monks
PostPosted: Mon Jul 26, 2010 7:41 pm
Bright_spark
Thanks for the replies :thumbright:
My consumer unit is ancient, so I re-wired the fuse wire, and the bulbs are fine...
I will check the wiring as you labelled below and come back to you
:cheers:
Monks
-- Mon Jul 26, 2010 9:28 pm --
Bright_spark - brilliant, 1st time, you're a star
Many thanks
:huray:
PostPosted: Tue Jul 27, 2010 1:26 pm
Your welcome! :salute:
