It is currently Fri Sep 21, 2018 6:47 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
PostPosted: Fri Oct 30, 2015 8:55 am
Has thanked: 52 times
Been thanked: 24 times
Hi everyone :-)
What i'm after is 2 round steel billets, or 2 square steel plates.
and an M22 or even bigger Hex head bolt.
The items don't even need to be in particularly good condition,
rust and dings are all good and only one side of each billet or
plate needs to be reasonably smooth. The thicker the billets,
the better.
I need a hole drilled into each billet / plate to smoothly fit
the bolt through and I need the bolt to be cut so it's shank
length does not exceed the thickness of the two billets / plates
stacked on top of each other.
The distance from the inner diameter to the outer diameter
of the billets can be a minimum of about 10mm to a maximum
of around 50mm
It would be nice, though not at all necessary for the bolt to be
placed through one of the billets and it's head welded to it
so it cant come back out again.
If anyone thinks they can sort that out for me, I can pay
for it on Monday.
Cheers :D
Noel
PostPosted: Fri Oct 30, 2015 9:15 pm
I'm gonna apply a little Occam's Razor here
This, admittedly would be a handy dandy little thing, but
I can just as easily accomplish what I need with a single
plate of steel on which to place the ring and a nice big M30 Bolt
for beating my rings into shape.
So nevermind about this one.
PostPosted: Fri Oct 30, 2015 10:01 pm
Has thanked: 96 times
Been thanked: 348 times
You just want a solid little anvil affair?
Cant see what the bolt advantage is over a block...?
PostPosted: Fri Oct 30, 2015 10:40 pm
If you are talking about the original idea?
The advantage relates to the way chainmaile rings form when struck
You could strike a chainmaile ring with a hammer, but unless it is a perfectly
placed hit, the ring will not flatten correctly, but will instead both flatten and
expand outwards.
Gold is a correctly formed ring, while pink is incorrect.
You can reduce the probability of getting the pink ring, by carbon scaling
your rings before beating them, this improves the grip the overlapped area
of the ring has, reducing the probability of it expanding.
You can place your ring between two plates and strike the top plate, this
further reduces the probability of getting the pink ring, but the same problem
applies. If the top plate is set on top of the ring at an angle, then striking it
can still cause an occasional pink ring.
So the most reliable way to eliminate the problem, is to make sure the top plate
and the bottom plate angularly identical and to do that, will require a bolt through
both plates, ideally welded to the top plate.
PostPosted: Fri Oct 30, 2015 11:01 pm
An alternate solution and this was the one I tried first, is
having 2 plates with 4 pins welded to the base plate. The
problem I had with this however was that if you accidentally
bend a pin, then the whole thing is instantly out of action.
PostPosted: Sat Oct 31, 2015 9:21 pm
I can probably help you with this one Noel...
What diameter are the 2 discs, about 60-65mm?
PostPosted: Sat Oct 31, 2015 9:55 pm
Has thanked: 26 times
Been thanked: 94 times
Sorry just couldn't resist it here is a LINK!
https://www.youtube.com/watch?v=nTTSTKesjGQ :huray:
PostPosted: Sun Nov 01, 2015 4:43 am
Outer diameter, 60-65 would be absolutely fine and basically
an inner diameter corresponding to the diameter of the largest
hex head bolt you can find.
If the 2 discs stacked were 40mm in thickness for instance, then the bolt
should be chopped so that it's length should not exceed 39 to 40mm.
Quote me on that when ya can and I'll send paypal payment, earliest
Monday.
Cheers mate
Noel.
PostPosted: Sun Nov 01, 2015 7:09 am
Interesting project, I was wondering how the jig will work when the link is being connected to other links of mail?
PostPosted: Sun Nov 01, 2015 2:32 pm
I can describe the basic process of weaving chainmaile for you toolbox
The process begins with 4 closed rings and 1 open ring
Place the 4 closed rings inside the opened one.
Now close the opened ring
Place this set on a flat surface and fiddle until the rings adopt this position
Repeat the process again and slide one set over the other
Loop an open ring through the overlap created by both sets
Now close the ring
This creates a simple strip of European 4 into 1 Chainmaile as discovered by the
ancient celts, adopted by the Roman Empire and ultimately used untill the invention
of the gun.
PostPosted: Sun Nov 01, 2015 4:38 pm
Thank you that explains it. I thought all the links would be closed, I wondered how you were going to do that. :scratch:
Must be a real labour of love to make a full set! It's fascinating to see old crafts kept alive, do you take part in re-enactments or just enjoy the challenge of making things like that?
Thanks ,
Best wishes, :thumbleft:
PostPosted: Sun Nov 01, 2015 5:06 pm
I'm not involved in any kind of reenactment society and do what I do
as a means to overcome the problems associated with sickness induced
isolation.
When I finally have the means to create riveted chainmaile, it might
naturally draw me closer to the world of reenactment and costuming
groups, both of which are sky rocketing in popularity these days.
I guess time will tell. :-)
PostPosted: Sun Nov 01, 2015 5:12 pm
:thumbleft: :thumbright:
Cheers!
PostPosted: Sat Nov 07, 2015 6:20 pm
Hows this Noel, about 65mm diameter, with an M24 bolt through.
Each half is 40mm high, so nice and solid....
Hole closely sized to minimalise slop, yet allowing ease of movement...
PostPosted: Sat Nov 07, 2015 8:11 pm
That looks perfect Hitch, how much would you like for it?
I'll pm you my address
