It is currently Sun Mar 24, 2019 5:39 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 11 posts ]
PostPosted: Wed Jan 04, 2012 7:37 pm
Has thanked: 21 times
Hi all
I've searched the forums and found a similar issue but not the same one so apologies if I'm re-treading old ground.
We've got a Worcester Greenstar 24i Junior or 28i Junior - not sure which as the manual is for both, I can't see it written on the boiler anywhere, and it was here when we bought the house.
Anyway I noticed recently I was having to top it up quite often as the pressure kept dropping from 2bar down to 1 or lower. I assumed I had a leak and started to worry. I had a dig through the forums here and thought I'd try a different tactic.
So, while it was down to 1bar, I turned the heating on. After about 20mins, I checked the gauge - it was back up to over 2bar. It's continued the same way for 2 weeks - I've not topped it up once, and every day it sits at just below 1 bar (basically just into the red) then if I turn the heating on, it leaps up by around a bar or so (slightly more I think) comfortably into the green but it looks like a massive jump considering the scale of the gauge. Then after the heating is off, it gradually settles back down to where it started.
Any ideas what this would be? Is it going to be expensive? Is it going to have been costing me a fortune in some way or have had any detrimental effect? The heating and hot water are seemingly fine so I'm wondering where to go next, rather than just calling someone out immediately.
Any advice very much welcome.
Regards,
Matt
PostPosted: Wed Jan 04, 2012 7:44 pm
Has thanked: 1535 times
Been thanked: 3869 times
:dunno: if you are topping it up every day or two..you have a problem..
If you were to set the pressure at say 1.2 bar, run it for a few hours, and it settles on cold at the same pressure..then you have no problem..
For this message the author wine~o has received gratitude : Joonyer
PostPosted: Wed Jan 04, 2012 8:05 pm
Hi mate cheers for the quick reply
Just to clarify, I've stopped topping it up. That was my strategy initially. In the last couple of weeks though, I've not been topping it up - it sits at around 1bar, then I turn the heating on and the pressure goes up to over 2 bar. I turn the heating off, and it drops back down.
If I top the boiler up when it's off (while at 1 bar) to say, 2 bar, then run the heating - the next day it's back down to 1 bar again. So could it be that it's overflowing when I top it up?
I just can't understand why it keeps going up when on, and down when off. Is there some sort of diaphram thing that could be knackered? I don't think it's a leak, because as I say, I've not topped it up for 2 weeks now and it's not gone any lower than 1 bar when off.
ta
Matt
PostPosted: Wed Jan 04, 2012 8:11 pm
Has thanked: 422 times
Been thanked: 3904 times
Check the pressure relief pipe stick through the wall for drips when the heating is on.
Sounds like an expansion vessel problem.
PostPosted: Wed Jan 04, 2012 8:19 pm
Been thanked: 181 times
i dont think there is a problem
just leave it on 1 bar when cold
For this message the author LordCross has received gratitude : Joonyer
PostPosted: Wed Jan 04, 2012 8:35 pm
When you think about it you are probably right.
The pressure will rise when the heating is on and drop as it cools.
For this message the author thescruff has received gratitude : Joonyer
PostPosted: Wed Jan 04, 2012 8:59 pm
Has thanked: 323 times
Been thanked: 969 times
As Scruff said earlier sounds like a flat expansion vessel.
thescruff wrote:
Most likely the expansion vessel.
Give the valve on the top a quick press and see whether you get a squirt of water or air.
There's two or three videos here that will help.
http://www.ultimatehandyman.org/video/c ... /index.php
Check out the vids. It does need sorting firstly because the don't repressurise themselves and secondly the pressure may well rise more when it's snowing and the heatings whacked right up!
Luckily topping up the expansion vessel is really easy on a Junior :wink:
For this message the author Razor has received gratitude : Joonyer
PostPosted: Wed Jan 04, 2012 11:58 pm
Expansion vessel that's it! When I was searching the forums it was that which gave me the idea to try not topping it up (to see if the symptoms were the same), then I couldn't find the threads/links again and couldn't remember the name of that vessel.
I reckon it is that, from what the other thread says - I'll give that a go tomorrow and let you know. Thanks a million gents hugely appreciated.
Matt
PostPosted: Thu Jan 05, 2012 12:10 am
Theres a few videos on how to check and top up correctly, worth watching before you start.
PostPosted: Thu Jan 05, 2012 7:46 pm
Evenin all :)
The manual I have doesn't mention the vessel anywhere. It's "User instructions and customer care guide" - I assume there's something more detailed elsewhere.
Does anyone know how I can get to my expansion vessel? I don't want to remove something and blow the house up or total the boiler. My knowledge of heating/boilers is precisely zero.
More than happy to have a go though, I'm pretty handy with other DIY and cars, it can't be that hard! There's a white round thing which looks to be a knob right at the top above the unit, where it goes outside. Is this related?
cheers
Matt
PostPosted: Thu Jan 05, 2012 8:00 pm
Right at the top at the back looking vertically down under the flue. You're looking for a car tyre type valve:
Here's a pic of a Junior expansion vessel that I just happened to have in the lockup taken from the same sort of viewpoint :wink:
