It is currently Sat May 26, 2012 12:04 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Thu Jan 05, 2012 7:51 pm
never worked one a worcester 350 before its the one with 2 pumps and no diverter valve.
hot water works fine heating fires up on demand but keeps cutting out at a low temperature so rads are luke warm,pump is fine and system is clear as sometimes it will work and rads heat up fast. any ideas??
PostPosted: Sat Jan 07, 2012 9:18 am
Has thanked: 9 times
Been thanked: 62 times
horrible horrible boiler
the fan has a resistor to it that cuts the fan down low after two seconds and if its knackered or on its way out the boiler will intermittently not work on heating
with these boilers it could be one of a hundred things, if you ring Worcester there no help at all, unfortunately if you find its a pcb problem you have to change both according to Worcester bloody Bosch
good luck personally i would fire it in to the sun from a cannon
