It is currently Thu Apr 19, 2018 12:49 pm
Visit Thermo worx
PostPosted: Thu May 05, 2011 9:58 am
I have not been able to get hot water out of the taps for 5 mins or almost a full sink bowl for over a month now. The pressure has been at 0 for over a month and would not go increase when turning the filler key.
I have had a gas man come out yesterday who had to add a new filler pipe to the bottom of the combi boiler. This one has two black mini levers that you turn to let flow through.
The pressure now increases when you turn these. The heating is working fine, however we still have the same issue with the hot water taking ages to heat up. For some reason it seems to come out quicker if i turn the heating on, which is silly.
Also, there is no LED light showing near the tap icon on the boiler either.
The gas man did mention that the large red cylinder had water at the back (which was dripping at times), but said he would be reluctant to touch this unless it gets worse as due to the pressure being low for a long time i might have an effect on it.
Any advice on why I am still not getting hot water as quickly as thought would be appreciated. From your posts it sounds like it could be Diverter Valve, but I am by no means familiar with heating/plumbing.
Thanks Graham
PostPosted: Thu May 05, 2011 1:02 pm
Has thanked: 422 times
Been thanked: 3903 times
I would have though the RGI stood in front pf it would have been the best guy to ask.
Are you say you have plenty of water, just it isn't very hot.
With the boiler pressure on 1.3bar, how high does it raise too when the boiler is working.
PostPosted: Fri May 06, 2011 12:19 am
Gas/Heating Expert
Has thanked: 27 times
Been thanked: 295 times
It sounds like a diverter valve fault.
Replacing these is a difficult job.
Perhaps the gas man was cleverer than he looked and knew that but did not want to get involved.
Obviously as you leave it for a month you have little interest in your boiler working correctly but obviously it needs the expansion system sorting as well as the diverter valve.
Tony Glazier
PostPosted: Fri May 06, 2011 8:56 am
Has thanked: 785 times
Been thanked: 847 times
I would advise calling Worcester in on a fixed price repair.
Sounds like the diaphragm gone, but usually you have to replace the diverter on these. b*stard job, one that I never take on either.
Expansion vessel shouldn't have water coming out of the test valve.
Dave
www.drlgas.co.uk
PostPosted: Sun May 08, 2011 10:52 pm
Has thanked: 24 times
Been thanked: 65 times
your div valve has definitely gone, not such a bad job as some say, i do them in about 40 mins. I charge £190 to do it. if you have a prob with the expansion vessel as well then its a no brainer get worcester in. They will do both for £215. i couldn't do both jobs for that! :wink:
