-> General DIY forum |
| Author |
Message |
georgelaney Junior Member
Posted: Mon Aug 11, 2008 5:37 pm Post subject: woodburner |
just a bit of advice if anyone can help.
i am fitting a woodburner in my kitchen and the chimney will be going out through a flat roof,does anyone have any advice or has anyone done this before and can give me any points that i may need to know.
any help is gratefully received. |
| Back to top |
thescruff Senior Member
Posted: Mon Aug 11, 2008 6:17 pm Post subject: |
Download and read very carefully Approved document J.
You would be better getting an expert flue Company in to supply and install the flue. _________________ Scruff |
| Back to top |
Posted: Mon Aug 11, 2008 8:54 pm Post subject: woodburner |
cant get anyone in as the run on the chimney is less than 4m so no hetas engineer will do the job.
i am going to use a turbo cowling on the chimney to give me the draw. |
| Back to top |
Posted: Mon Aug 11, 2008 8:59 pm Post subject: |
If the flue doesn't clear the building it is likely to be illegal.
Ask yourself why the engineers will not do the job, you also need to get it past building control. _________________ Scruff |
| Back to top |
Jaeger_S2k Senior Member
Joined: 19 Nov 2006 Posts: 2786 Location: North West, England, United Kingdom
Posted: Mon Aug 11, 2008 10:57 pm Post subject: Re: woodburner |
| georgelaney wrote: |
 _________________ Jaeger.
FSBF |
| Back to top |
