It is currently Fri Feb 22, 2019 3:02 pm
PostPosted: Mon May 14, 2018 9:21 pm
I have recently had my garden fully wired (radial system ... unsure that means) in each corner by a profession electrician. I have been informed that I can run electric heaters, kettle, etc. with no issue and it runs from the consumer unit in my garage which I think is connected to a 65 amp RCD fuse and he said if I wanted to run power to my new shed then I can merely spur off of one of the double sockets to a separate fused switch.
Ok so what I want to do is be able to move my shed in and out to maintain it every year so was thinking of using a one of those IP67 adapters like you see when connecting caravans to cars, so having a fixed socket on the fence and have a trailing flex from the shed. The trailing flex I was going to attach to the shed and then on to a new smaller consumer unit in the shed (x1 for lighting and x1 for plugs) ... does this sound ok?
I'm a competent diy-er just wanted to know the best (not necessarily the cheapest) way to do this and what parts to look out for, cheers for any advice?
PostPosted: Tue May 15, 2018 11:43 am
Has thanked: 65 times
Been thanked: 553 times
The plugs used with caravans do go wrong, it has to be plugged in, you could not hard wire a caravan, but because they know it can go wrong there is a slight change in rules to standard house, that is the use of double pole switching.
To have the shed wired to a plug and when you want power in the shed you plug it in great, but to leave plugged in, insects and spiders are likely to get into the plug and also water could get in.
You may to be fair get away with it for 10 years or more, but what tends to happen is faults arise which are never detected until too late. Yes we should do an EICR at least every 10 years, but we all also know we don't.
No one has defined temporary, the pre-fab houses built just after the war were temporary, and still in use today. But personally I would hard wire, and would not simply plug it in.
PostPosted: Wed May 16, 2018 10:03 am
Thanks ... I will consider hard wiring. If I do what do you recommend inside the shed, as in I have a cable coming into the shed, this will need to be water tight somehow, I want to add a double socket at least inside and some form of lighting wiring?
PostPosted: Thu May 17, 2018 4:52 pm
Approved Electrician
Has thanked: 168 times
Been thanked: 585 times
I cannot see what is wrong with powering the shed from a waterproof socket
PostPosted: Fri May 18, 2018 5:25 pm
I didn't know if that was acceptable or not, so wanted some advice.
fyi - just looked and the garden radial in on a 16 amp fused back on the consumer unit ... so I could take the power in thru a waterproof box, then into an isolating switch inside the shed, then feed the sockets from that isolator, then spur off the isolator to a second fused spur set at 5amp (?) for the lighting ... sound ok?
PostPosted: Fri May 18, 2018 7:17 pm
Yes.
I suggest the use of SY cable between the shed and your power source
