It is currently Sat May 26, 2012 12:02 am
PostPosted: Sat Dec 10, 2011 6:07 pm
Has thanked: 1 times
I am installing some new outdoor sensor lights around my home, to replace older sensor lighting.
The wiring I am using will be the exisitng 3-Core + earth cable.
For the old lights, they were continuously on sensor mode plus there was a separate override to allow me to switch them on permanently. The lights themselves had connections for L, N, E + also a fourth connection for the 3rd yellow wire in the 3-core. I guess this is what went to the overide switch.
However, the new lights only have connections for L, N, E. Can anyone explain how I should wire the 3 core to this to enable me to have them on sensor under normal operation + the override option to switch on permanently if required.
Many thanks.
PostPosted: Sat Dec 10, 2011 7:05 pm
Has thanked: 25 times
Been thanked: 71 times
Sounds very much like your new lights have not got that override facility :cb
PostPosted: Sun Dec 11, 2011 9:33 am
I guess that might be the case. Painful. Any ideas anyone?
PostPosted: Sun Dec 11, 2011 2:54 pm
Been thanked: 4 times
It'll probably have a power on/off trigger for manual overide. Turn off/on within 1-2 sec - goes into manual/constant on mode. Turn off for more than 10/15 secs then it goes back to auto/sensor mode. Read the instructions.
As it is, seems like you don't need the yellow core - make sure to isolate it at both ends if you can, othewise be sure to put something appropriate at the light end to isolate it.
PostPosted: Sun Dec 11, 2011 4:05 pm
Has thanked: 7 times
Been thanked: 66 times
I would say it is the yellow core that he needs to use to power the lights as this is the switched live. The red is a permanent live (assuming that a madman has not used the blue for the permanent live).
So the red would need to be appropriatly isolatated not the yellow.
For this message the author OnlyMe has received gratitude : DeanoBeano
PostPosted: Sun Dec 11, 2011 8:59 pm
Thanks. Have connected yellow core and isolate red. That works for normal senor operation. But manual overide not working based on manu instructions of switchin "of-on-of-on". Will talk to manufactureres.
Users browsing this forum: StormFusion and 3 guests
