It is currently Thu Jan 17, 2019 3:04 am
PostPosted: Mon Feb 05, 2018 9:51 pm
Need some advice on whether I can replace my current normal dimmer switch with a Dimmable Smart Switch. (Lightwave Generation 2)
There are 3 switches that operate the lights on the first floor landing.
One switch is at the bottom of the stairs, the other switch is at the top of the stairs on the first floor and the third switch is along the landing on the first floor too.
The current dimmer switch is in the middle ( at the top of the stairs). It uses L1, L2 and common wires plus an earth attached to the back plate.
The Smart Dimmer Switch has 3 connections which are L / S / and the wave line (think this is common).
The details on the smart switch say that it does not require a mains neutral switch to be connected.
There is a video online which mentions the following wires that need to be connected.
Switch Live Out / Signal Connection / Live In
https://www.youtube.com/watch?v=icmd9l4lux0
So do I cap the mains neutral wire and connect the Live to (L) and Common to (Wave) on the Smart Dimmer?
I have drawn up a diagram that helps explain the above.
Any help would be much appreciated.
File comment: Light Switch Diagram
PostPosted: Mon Feb 05, 2018 10:06 pm
Has thanked: 39 times
Been thanked: 1405 times
Are you saying you have 3 switches that control the same lamp.
And one of these switches is already a dimmer, and you want to change this dimmer to a "smart dimmer"
PostPosted: Mon Feb 05, 2018 10:09 pm
Yes thats correct.
PostPosted: Mon Feb 05, 2018 10:12 pm
I just watched the video you linked to, watch it again and look at 2.29. it answers your question
PostPosted: Mon Feb 05, 2018 10:20 pm
So it can't be used with the other 2 standard switches I have but can be used if I replace all 3 switches with Smart Switches. Is that right?
PostPosted: Mon Feb 05, 2018 10:38 pm
I have never used the switch you mention, I only can only watch the same video you can, I can only read the same as you can.
:sign7: why dont you get one of These
That way you will not need any switches, and if you have one of these you can tell the light to turn on / off (and what colour)
Did you know that for your dimmer to work you have to buy a "Link plus" device too (But that may be just to get it to work as a smart device)
The lamp I mention costs considerably less and is over all more fun. (I have two so far)
PostPosted: Mon Feb 05, 2018 10:53 pm
Thanks for the alternative solution.
However I have connected Lightwave Smart Switches and Sockets to the ground floor rooms. All working through the Link Plus and Apple HomeKit plus connected to Alexa for voice control.
Its the wiring to the 3 switches that I need help on.
Thanks for your help.
PostPosted: Mon Feb 05, 2018 11:08 pm
Why? You have already answered your own question, hence my alternative.
PostPosted: Mon Feb 05, 2018 11:16 pm
Do you know how to wire the Switches in my question?
Switch number 2 would be useful to know how to wire first.
That would be helpful.
PostPosted: Tue Feb 06, 2018 5:15 am
I can only go by the same video you linked to, (I have never seen them in detail before) to me it says they are all wired the same, but then may be its the wrong video because the switch does have a label that says "slave" I would have thought the first one would say "Master" Since you have one, and I don't, what do the instructions say you should do?
PostPosted: Tue Feb 06, 2018 7:28 am
The dimmer switches are all the same. They have the same L / S / wave line connections.
PostPosted: Wed Feb 07, 2018 3:40 am
Has thanked: 65 times
Been thanked: 546 times
As I understand it with two way dimmers you have master and slaves, so with the lightwaveRF the master is connected to the hub and the slaves connect to master using the S terminal, so you would need one master and two slave dimmers. It will not work with a normal two way or intermediate switch.
So from what I am reading the switches should not be all the same, one is a master and two are slaves.
PostPosted: Wed Feb 07, 2018 6:24 pm
Has thanked: 1509 times
Been thanked: 3834 times
:welcomeuhm:
No idea about the original question but you do not have a neutral at the switch. you have a single permanent live and switched lives.
