It is currently Mon Mar 25, 2019 8:37 am
PostPosted: Wed May 16, 2018 12:04 pm
Hi there. Im a basic diyer.
Wiring in plug sockets and plugs is about my limit.
I have a garden light with motion sensor and want to wire to a plug. Looking at the photo attached working from top to bottom on left hand side of connector block is as simple as top left live to top right live. Left second connector is where the earth will connect and finally neutral into third left hand connector.
Is this right?
Should i connect to 3amp plug?
Thanks in advance.
PostPosted: Wed May 16, 2018 6:06 pm
Has thanked: 41 times
Been thanked: 1448 times
What do the instructions say? (And there is no such thing as a 3A plug) If you mean a Standard UK plug with a 3A fuse then yes.
PostPosted: Wed May 16, 2018 6:11 pm
Has thanked: 1535 times
Been thanked: 3869 times
:welcomeuhm:
Bit of a mix of colours there, as per S/E's post, surely it came with instructions ?
PostPosted: Wed May 16, 2018 6:24 pm
Approved Electrician
Has thanked: 170 times
Been thanked: 589 times
:welcomeuhm:
You are correct.
The top terminal is your live in, the second terminal is the earth and the third terminal is the neutral.
PostPosted: Wed May 16, 2018 6:26 pm
Has thanked: 706 times
Been thanked: 2037 times
could be seeing things but second contact from the top seems to have a tab from the washer going in to it as the earth :dunno:
PostPosted: Wed May 16, 2018 6:45 pm
I have already downloaded the instructions for a look. I can now see why the OP is double checking his connections.
Instructions here
https://www.endon.co.uk/UploadedAssets/ ... t%20v3.pdf
They are not very good are they?
PostPosted: Wed May 16, 2018 7:19 pm
Sooo the top (spare) terminal is for the live loop (if there is one) ???
PostPosted: Wed May 16, 2018 8:15 pm
No.
The top terminal is either permanent live or a switched live from a lightswitch (if the lightswitch is off the light will not work)
PostPosted: Thu May 17, 2018 10:29 am
Thanks for the replies. No wiring instructions at all and have I have two of these units!
Should have enough to go on now.
Much appreciated.☺
