It is currently Fri May 25, 2012 11:57 pm
 Post subject: Wiring an electric oven
PostPosted: Fri Dec 30, 2011 5:23 pm
Hi
We have recently purchased a new oven which is due for delivery tomorrow.
When i have removed the old oven today there is a double socket outlet, the oven was plugged in to one of the outlets with a 13amp plug the other has the gas hob plugged into it. I was just wondering if this is correct? I was under the impression that the oven would need to be hard wired to a spur?
If the oven comes tomorrow and requires hard wiring can i just put a plug on the end and plug and play?
I should add that above the worktop there is a red isolating switch where the double s.o can be isolated. There is also a breaker on the mains db labeled cooker.
Thanks in advance
Jono
PostPosted: Fri Dec 30, 2011 5:38 pm
Has thanked: 166 times
Been thanked: 614 times
If the oven (when it arrives) has a plug connected then you're good to go...if not then it'll possibly need a dedicated feed from your consumer unit..depends on the Kw rating of the oven.
If you have a link to the oven, or know what the rating is (Kw or Amps) then can advise further..
PostPosted: Fri Dec 30, 2011 5:54 pm
The oven is a hoover HOC706X
Link as follows
http://www.dixons.co.uk/gbuk/hoover-hoc ... 4-pdt.html
PostPosted: Fri Dec 30, 2011 6:01 pm
Has thanked: 134 times
Been thanked: 474 times
"Requires hardwiring Yes - 13 Amp cable without plug connected."
lifted from the blurb
PostPosted: Fri Dec 30, 2011 6:06 pm
So can i just wire to a 13amp plug?
PostPosted: Fri Dec 30, 2011 6:07 pm
Less than 1KW...surprised it says on the dixons site that it needs hardwiring..I'd be tempted to put a standard plug on it...However we don't want to invalidate the warranty, so I would suggest a short length of 2.5mm T & E to a FCU, fused at 3A, hard wire into that.
(T & E is twin and earth, FCU is one of these http://www.toolstation.com/shop/Electri ... 633/p28571 )
Though I can't see why a Plug with a 3 amp fuse wouldn't do as well....
PostPosted: Fri Dec 30, 2011 6:35 pm
Thanks, i will probably put a plug on it then as i still need the other outlet for the gas hob
PostPosted: Fri Dec 30, 2011 9:12 pm
i would expect it to be nearer a 3kw oven its quoting kwh so assuming once up to temperature it cuts down or off averaging 0.79kwh but this is just a guess as i dont know :dunno:
Users browsing this forum: OnlyMe and 3 guests
