It is currently Fri May 25, 2012 11:56 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Sat Dec 03, 2011 3:17 pm
Has thanked: 15 times
thescruff wrote:
Yes.
Where you see the link (E) remove it, the left connection is NO in the stat and the right connection is COM. no other wires are needed
Done, but not working! ::b
I've removed the link and wired the left connection to the NO in the stat and the right connection to the COM.
Should I try the NC instead?
PostPosted: Sat Dec 03, 2011 3:22 pm
OAP
Has thanked: 187 times
Been thanked: 2115 times
dylanp wrote:
thescruff wrote:
Yes.
No, unless you want to blow something up and have a very expensive repair bill.
Have you set the stat, follow the instructions.
PostPosted: Sat Dec 03, 2011 3:34 pm
I'm working on it now, thescruff. The instructions are pretty darn poor.
PostPosted: Sat Dec 03, 2011 3:45 pm
ericmark wrote:
There is no direct connection to mains. The 2.7 wiring diagram is miss leading. It just two wires replacing link going to com and NO.
Apparently so, eric, but, alas, I'm getting nothing having followed those instructions. ::b
PostPosted: Sat Dec 03, 2011 3:54 pm
I think I have it. The boiler was still on timer-mode. I've switched it over now and the stat seesmt to be controlling it. I bought this stat because, in B&Q they advertise it as having a timer function (ie the option to turn the boiler on at preset times). I think that is incorrect. I can only turn the boiler on/off by manually pressing the applicable button. Still, that's not down to the wiring!!
Many, many thanks to all who provided info, particularly thescruff and ericmark. Thanks again, gents!
PostPosted: Sat Dec 03, 2011 4:00 pm
OAP
Forget this you have already wired it up, assuming you have done as I said.
All you need to do is follow the instructions, in the numbered order.
Have you sorted the batteries for example, do you have a display
PostPosted: Sat Dec 03, 2011 4:04 pm
Yes, I have a display. I'm trying to work the operating features out now. The good news is I can turn the boiler on and off remotely from the stat now, so the wiring is obviously correct. Thanks for the very clear and concise instruction, thescruff!
Users browsing this forum: OnlyMe and 2 guests
