It is currently Mon May 20, 2019 3:48 pm
PostPosted: Thu Apr 26, 2018 4:42 pm
Has thanked: 2 times
I want to replace an existing British Gas PT2 thermostat with a Drayton Digistat + 3RF (seperate thermostat controls and receiver).
However, when looking at the Receiver and reading the wiring instructions it seems that I should have three wires, but the existing thermostat has only two.
I've photographed the new plate above the existing plate. The terminals read as follows.
New: N L 1 2 3 4
Old: 1 2 3
It seems that the existing wiring is Live to 1 and Neutral to 3.
Can I replace the existing plate with the new one (i hav ebeen told I should be able to), and if so how should the wiring go?
Many thanks
PostPosted: Thu Apr 26, 2018 5:42 pm
Has thanked: 1560 times
Been thanked: 3911 times
:welcomeuhm:
Better asked in the central heating section. I'll see if I can get the Mods to move it.
PostPosted: Thu Apr 26, 2018 6:24 pm
Has thanked: 840 times
Been thanked: 941 times
I would expect 4 wires to the receiver box.
Perm L & N and live into and out of the switch from the boiler/ wiring centre.
Depending on your set up you could possibly link the live from the permanent live.
Dave
www.drlgas.co.uk
PostPosted: Thu Apr 26, 2018 6:49 pm
Hello Dave and thanks for the prompt response. This is the first time I've looked at the existing receiver box since it was installed by British Gas. I've attached a photo the section from the Instruction leaflet, which doesn't make much sense to me.
PostPosted: Thu Apr 26, 2018 8:45 pm
That’s showing exactly what I would expect in the receiver box.
Assuming you are putting the receiver box next to the wiring centre or boiler if it’s a combi.
What boiler/system do you have?
Dave
www.drlgas.co.uk
PostPosted: Fri Apr 27, 2018 7:42 am
Hi Dave,
It's a British Gas 532 Combi, no doubt made by Worcester but can't say what the Worcester Model number would be. Although it's fairly old it's been serviced yearly by BG and it was one of their engineers who said the thermostat could be swapped, but wouldn't come under the agreement.
PostPosted: Fri Apr 27, 2018 10:07 pm
Has thanked: 85 times
Been thanked: 81 times
gas4you is probably busy at the moment so I will try and help in his absence.
The two wires connected to your old room stat are probably a live and a switched live back to the boiler.
Your new receiver needs a permanent live and neutral to power it, plus the switching wires to control the boiler. You could mount the receiver in the same location as your old stat but you would need to provide a live and neutral and then transfer the switching wires 1 and 3 from your old stat across to 1 and 3 on the receiver.
As gas4you has said, normaly the receiver is mounted close to the boiler as this makes it easier to pickup a live and neutral and feed a switched live back.
For this message the author PLB has received gratitude : gas4you
PostPosted: Sat Apr 28, 2018 7:12 am
chunya wrote:
Hi Dave,
Good Morning,
Many thanks for that. It seems that the job is outside my area of competence so best left to a professional.
All the best
