It is currently Fri May 25, 2012 11:52 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 19 posts ]  Go to page 1, 2  Next
PostPosted: Tue Nov 08, 2011 9:37 pm
Has thanked: 8 times
Hello,
Ive got a Alpha C27 boiler and wish to fir a wireless thermostat to control temp rather than the analog clock it has now.
Ive read on here that the boiler will need 230v switching.
The majority of stats I see seem to have no volt switching.
Are such wireless thermostat that have a 230v switch available?
Many thanks :thumbleft:
PostPosted: Tue Nov 08, 2011 11:33 pm
Has thanked: 6 times
Been thanked: 96 times
No volt means you select the supply and it could be 24v or 230v the option is yours. With 230v you will likely need to have a link fitted.
PostPosted: Tue Nov 08, 2011 11:55 pm
OAP
Has thanked: 187 times
Been thanked: 2115 times
It connects to 1 and 2 in the boiler after you remove the link.
Look at the Honeywell DT92E.
PostPosted: Wed Nov 09, 2011 6:09 am
Ah right thank you very much for that!
Had no idea that's what it meant.
Will take a look at that thermostat thanks.
PostPosted: Wed Nov 09, 2011 9:55 am
OAP
Remove the link in the boiler 1-2, or post back if it already is.
T1 goes to A.
T2 goes to B.
edited
And you need a neutral and live.
DT92E-Installation-Guide.pdf [924 KiB]
Downloaded 32 times
PostPosted: Thu Dec 01, 2011 12:54 pm
T1 goes to A.
T2 goes to B.
You also add a link between A - L.
And you need a neutral.
Hello again. A quick update. I bought the CMT927 model.
just to clear my mind here, I have 230v L and N going to the relay box.
I have linked the L to terminal A.
I am now going to get some flex from work to finish the wiring off so just I now next I should....
Remove the link from T1 and T2 in the boiler.
A to T1 and B to T2.
What do I do with the existing clock as currently there is a link from the 230v L to T2 which is putting permant supply on clock? Does this just get disconnected?
The red wire out of T1 goes to a N/O contact on the back of the clock, the otehr contact then going onto circuit board. This will need linked also?
PostPosted: Thu Dec 01, 2011 1:09 pm
OAP
Ok so it's all changed, you don't need the link from L to A in the stat.
Remove the link 1 to 2 if in place.
A goes to 2 in the boiler and B goes to 1 in the boiler.
What timer do you have.
PostPosted: Thu Dec 01, 2011 1:27 pm
thanks for such a quick reply, i did wonder about A going to 2 because of the mentioned link.
The clock is just the standard option that is fitted in them as far as i can tell, matches the one in user guide.
PostPosted: Thu Dec 01, 2011 1:39 pm
OAP
A little confused, is the clock wired to the internal clock connections or the boiler connection block.
Perhaps a pic before you start.
PostPosted: Sat Dec 03, 2011 9:06 am
There you go mate,
The Red in T1 goes to number 4 on the internal clock, 3 goes to the connector at top left centre of board
The brown out of T2 goes to the supply of internal clock number 2
PostPosted: Sat Dec 03, 2011 10:43 am
OAP
Can you identify the numbers on the connectors on the left of your pic.
The two with the red link we are interested in.
PostPosted: Sat Dec 03, 2011 11:21 am
OAP
I modified the manual for you.
If you remove the link the switched live B goes to terminal 1, and A goes to terminal 2.
PostPosted: Sat Dec 03, 2011 4:07 pm
identifying the terminals T1 on on the left and T2 on the right.
My wiring is defo different to the wiring diagram thouugh.
Think im with you will give it a go :thumbleft:
PostPosted: Sat Dec 03, 2011 4:19 pm
OAP
This is what the stat should look like.
Note I changed the T1 and T2 numbers over to suit the boiler.
PostPosted: Sat Dec 03, 2011 4:25 pm
yea no problem with that thanks.
will go wire it up in a few mins
T2 will have 230v on it from the link in the boiler though yea?
