Page 1 of 1
[ 6 posts ] |
| Author |
Message |
halfprice
Posted: Wed Nov 02, 2011 8:04 pm |
| Newly registered Member |
Joined: Wed Nov 02, 2011 4:42 pm Posts: 3 Has thanked: 1 times Been thanked: 0 times
Im new to the forum just wanting a lead in the right direction. i have a new potterton 28he combi boiler and i fitted the 24 hr timer switch what come with it.. i now want to install a wireless room stat to it. what i want to know is can i fit the wireless stat and leave the 24hr clock in tact or do i have to isolate the 24 hr clock before i fit the new wireless stat. Helpful advice would be appreciated..
| Top |
white pan man
Posted: Wed Nov 02, 2011 8:16 pm |
| Senior Member |
Joined: Thu Jul 07, 2011 11:42 am Posts: 775 Location: london Has thanked: 57 times Been thanked: 99 times
Well if you are just fitting a wireless thermostat you will need to keep the clock,as both items will be used in daily operation of heating
If you are fitting programmable wireless thermostat you will disconnect the clock on the boiler so it does not over ride the new unit
_________________ If you have found help on the UHM's forums,why not help out the UHM's Nominated Charity,find out more here donnas-dream-house-charity-t52110.html
| Top |
register or
log in
halfprice
Posted: Wed Nov 02, 2011 8:24 pm |
yes it is a 7 day programmable wireless stat.. so to isolate the wires on the 24hr clock (live neutral and 2 black wires) what do i do with the 2 balcks keep them seperat or do i link them together??
| Top |
register or
log in
white pan man
Posted: Wed Nov 02, 2011 8:39 pm |
| Senior Member |
Yes link them together or you can just leave clock on constant,I prefer linking out clock as stops human operation error in future
| Top |
register or
log in
halfprice
Posted: Wed Nov 02, 2011 8:49 pm |
great thats what i thought just a thought there wouldnt be a problem if took blacks off and linked them and left the live n neutral connected to the clock ????
| Top |
register or
log in
white pan man
Posted: Wed Nov 02, 2011 9:15 pm |
| Senior Member |
You can do that or follow wiring back to main terminal block and disconnect and link black wire terminals there
| Top |
register or
log in
Page 1 of 1
[ 6 posts ] |
